Plasma LG 42PC3RA led blinking
    Re: Plasma LG 42PC3RA led blinking
    hello
    bad news
    I changed the stk but the problem is the same
    1 time red LED and then 5 time green and finaly fix LED green
    the remote control works
    and always this noise power decoupage in default
    thanks for your help
      Did you change the fuse as well ?
        Originally posted by mmartell View Post
        By the way Reecey you got your left and right mixed up
        Ohh yeah haha doh well Ymain is on the right when the screen is facing you haha
          good evening
          yes all fuses are ok
            hello
            i have make some test today
            here some measure
            Vy 6v
            Vsc-125 V
            Vzbias 100 v
            on my tv
            this is not picture of my tv
            but only Vsetup is N.A
            it's ok Vy is not good
            any idea
            thank for your help
              Ok and Vs and Va are good ?
                hello
                184 for Vs 60 for Va
                with or without cards plugged
                correct voltage
                  Ok Vy isnt correct, in a dark room does the screen glow at all ?
                    nothing on screen
                    only remote work
                      Hmm well Vy isnt correct, thats generated by Ysus reading up now a bad Ymain Ipm can cause no Vy.
                        Vy is out
                        ipm is new and the symptom is same
                        i search where product Vy
                          Ipm is "new" ? Where did you get it ? Most are pulls at this late stage of the game.
                            good evening
                            some new
                            Vy is ok 200 volts i think ipm work good
                            when I unplugged the cable between the card ysus and card t-con
                            t-com fault ??
                            mmartell yes new ipm never solderered possible to found it
                            thank for your help
                              Does sound like Tcon fault
                                Cheap enough to replace it (at least here) but something tells me it's not the problem. Without the control board ribbon plugged in the ysus isn't asked to do much so very possible to see Vs until it's asked to create a waveform. Still think you have ysus problem.
                                  hello
                                  i waiting for y-sus card
                                  i come here later
                                  bye
                                    hello
                                    good news
                                    mmartell : respect !! y-sus fault !!
                                    picture is back on my tv
                                    but not perfect
                                    i have red snow on black picture
                                    any idea ?
                                    thank for your help ReeceyBurger123 and mmartell
                                      Nice one Red snow ehy how bad can you take a picture Steph ?
                                        hello
                                        here some picture
                                          Not a Zsus issue, have you tried adjusting the Panel voltages ? Also you might need to update the firmware on the control board.
