Plasma LG 42PC3RA led blinking
  • daroo
    • Oct 2014
    • 63
    • ITALY
    I have this 42 inch plasma, the problem is that I have no image.
    Opened the back and I found a bad 3300uf cap and replaced it, I have also replaced the other 3 that were near the bad one.
    The tv still doesn't work, I ear the relay clicking but there is no picture. the green led blinks.
    The fuse near the 220v imput is ok, and also the fuses in the other boards.
    I have checked the voltages: Va: 58v and Vs: 0.2v (but only between the first and second click of the relay)
    it should be : Va:60v and Vs:185v
    Is there something I can check to find the problem?
  • daroo
    • Oct 2014
    • 63
    • ITALY
    Re: Plasma LG 42PC3RA led blinking
    i've disconnected the y-sus and the green led stays on. Checked all the voltages and they are ok. So I think it's the IC on the y-sus because i found that is a common problem.
    The chip is 4921QP1037A.
    I'll try to change it.
    Is it the correct way to solve the problem?
    • daroo
      • Oct 2014
      • 63
      • ITALY
      If I disconnect the ysus the tv turns on with no picture but sound.
      I removed the ic under the heatsink on the ysus because it looked shorted with my multimeter and I have read it's common that this hybrid ic goes bad.
      I will order the sanyo equivalent and try the swap. Is there something I can check to see if there is anything else shorted?
      Wish me good luck, this swap will be a tricky job for me
      • daroo
        • Oct 2014
        • 63
        • ITALY
        The right chip was STK795-821, I ordered it from china for 22$.
        Soldered in place and the tv is working fine, no red sparkles. no need to adjust voltages.
        Very very good, thanks to this fantastic forum!
        • steph06000
          • Sep 2015
          • 21
          • france
          hello
          i search to repair my lg
          and i have same symptom
          one question to you
          when you say disconnected y-sus
          you say all connections or just supply ??
          thank for your answer and sorry for my english
          bye
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Steph take pictures of the back of your tv please.
            • steph06000
              • Sep 2015
              • 21
              • france
              hello
              not mine but the same
              bye
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Ok the Ysus is the large board on the right of the set and the Xsus is the board on the left, they have big power cables going to and from them unplug them at one end and see if the tv at least powers on.
                • steph06000
                  • Sep 2015
                  • 21
                  • france
                  hello
                  i have have unplug all card but same led blinking
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Ok so you have a Dmm ?
                    • steph06000
                      • Sep 2015
                      • 21
                      • france
                      when you write Dmm it is digital multimeter ?? yes y have
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Yes, ok right do you get the Vs and Va voltage on the psu with Ysus and Xsus disconnected ?
                        • steph06000
                          • Sep 2015
                          • 21
                          • france
                          184 for vs 60 for va
                          with or without cards plugged
                          i have replace c49 on y-sus but same problem
                          i have clicking sound on y-sus
                          no shorted vs/gnd on board fuse ok
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Ok checked fuses on Zmain and Ymain ?
                            • steph06000
                              • Sep 2015
                              • 21
                              • france
                              fuses ok on all cards
                              • mmartell
                                • Oct 2013
                                • 3189
                                Is the sound a ticking and is it coming from the large heatsink ? The ipms can also fail "open" causing them to tick instead of shorting and blowing the fuse.
                                If so it would need to be replaced.
                                • mmartell
                                  • Oct 2013
                                  • 3189
                                  By the way Reecey you got your left and right mixed up
                                  • steph06000
                                    • Sep 2015
                                    • 21
                                    • france
                                    ok
                                    I go to buy STK795-821
                                    cross the finger !!
                                    thanck for your help
                                    when Soldered i come back here for news
                                    bye
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      Ok let us know Steph
                                      • mmartell
                                        • Oct 2013
                                        • 3189
                                        Posted in the wrong thread...
                                        • SevenOFF
                                          Denon AVR-X4000 – Fast red blinking after 2nd relay
                                          by SevenOFF
                                          I’m working on a Denon AVR-X4000 that goes into protection mode (fast red blinking LED) shortly after the second relay click.
                                          According to the service manual, a fast red blinking LED indicates a DC detection (DC_DET) or ASO (abnormal current) fault, meaning the unit is detecting a potentially dangerous condition on the power amp or power supply side.
                                          Here’s what I’ve done so far:
                                          • Fully opened and cleaned the unit (a lot of dust inside)
                                          • Removed and visually inspected the AMP board → nothing visibly damaged or burned
                                          • Testing is done with
                                          06-18-2025, 09:54 PM
                                        • jm1234
                                          9V relay temperature 40C
                                          by jm1234
                                          Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                                          I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                                          05-09-2024, 03:03 AM
                                        • edugimeno
                                          Biomass Boiler not driving cleaner motor relay. ENERTRES BIOMASA BI-650
                                          by edugimeno
                                          Hi everyone!
                                          I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
                                          I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
                                          This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
                                          To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
                                          I respected the polarity, positive to cathode of protecting diode
                                          So provided all...
                                          04-18-2024, 01:15 PM
                                          Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                          by sam_sam_sam
                                          I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                          The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                          Found shorted diodes on main controller relays there are 3 of them that...
                                          01-07-2023, 05:43 PM
                                        • CoinCoin88
                                          Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                          by CoinCoin88
                                          I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                          Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                          09-15-2025, 03:36 AM
