32la30rq half screen frozen (Pause)
  • JCdes
    • Feb 2013
    • 91
    Hello guys! I was given an RCA 32LA30RQ, this TV will work fine for a few minutes then the top half of the screen freezes like if it was in "pause", you can see the bottom half moving and sound is ok, no color problems either just this weird problem. Any ideas?
  • KevinCro
    • May 2014
    • 104
    Re: 32la30rq half screen frozen (Pause)
    could you post a picture of the inside of the tv where we can see the boards. I've seen tab bonding cause this sort of behavior. Be careful working inside the tv.
    • KevinCro
      • May 2014
      • 104
      You can also go to radio shack and buy some component cooler and spray inside the front bezel so that the outer most edges of the panel are cooled. If the picture unfreezes then you probably have a tab bonding failure.
      • Chrissygizmo
        by Chrissygizmo
        02-10-2025, 12:33 AM
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • valvashon
        LG 55UH6150- trouble powering up, then half lit screen (pictures!)
        by valvashon
        The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
        Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
        11-24-2024, 12:08 PM
      • Raulnn
        TD Systems K50DLG12US half black and half white screen
        by Raulnn
        good night! I have this screen that looks half black and half white. the tcon gives a low vgh value (5-6v). the rest seem fine. I first removed the flex from one half of the panel and then the other. Removing the left, vgh increases it to 25-26v. I think the problem is in that area, but there are not many elements on the integrated controller board. there are no shorted capacitors. could they be a cof? Some help?
        By the way, now the entire screen is black. Maybe some flex was not connected correctly... I have exchanged the flex and there are no variations, I don't think they are the...
        01-20-2024, 04:49 PM
      • scubacamper
        Sharp Aquos LC-70C6400U Half Screen Dark
        by scubacamper
        I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
        Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
        when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
        05-03-2025, 12:19 PM
