Sony 52V5100 TV - fuzzy picture
  • nittamk
    • Nov 2014
    • 10
    Working on my daughter's TV. Symptoms: no picture (black screen), no audio, when power on-backlight on for about 3 seconds-about 3 seconds later switch RY6101 on Power supply board clicks off. Read some Sony TV threads and did the following stuff: Checked F1 SMD fuse on the T-Con, 12.13v on one side and 1.44v on the other when the backlight is on. Resistance across F1 is 1800 ohms. Jumper across F1 with clip, no audio, and slow motion picture - looks like a refresh picture problem. The images seem to fade in/out slower than normal, looks like ghosting.
    I don't have schematics, and this is the first LCD for me. Worked on CRTs a long time ago.
    Need advise to fix the "slow motion" picture and audio.
  • nittamk
    • Nov 2014
    • 10
    Re: Sony 52V5100 TV - fuzzy picture
    Found the audio problem, it was set to direct audio to a external amp, not the TV speakers. So I have audio. still researching the fuzzy picture.
    • nittamk
      • Nov 2014
      • 10
      Update: tried all of the tabs, no change in the fuzzy picture, still in slow mo.
      Help!
      • freakaftr8
        • Oct 2012
        • 3743
        I'm working on a similar problem with a 46 inch sony. Blown fuse in tcon replaced now slow motion .it's a tcon problem. May not be repairable if it's a main processor on the board.
        • nittamk
          • Nov 2014
          • 10
          Thanks. I'm slowly coming to the same conclusion. May try a new T-Con board.
          We have might have a Sony repair center here so I think I may visit them.
          By the way, I did replace F1, the LF 7a SMD fuse, with an equivalent barrel fuse, no one here had SMD fuses.
          • nittamk
            • Nov 2014
            • 10
            Update: The Sony service center does not have the T-Con board and does not intend to keep a stock of this board. I asked if the refresh is controlled by the T-Con, the reply was that the Main Board controls the refresh. The service center does not stock the main board either. I intend to take an better look a my TV main board now.
            • freakaftr8
              • Oct 2012
              • 3743
              Doubt your mainboard is an issue. if your fuse is blown on your t-con there's something wrong with the t-con board. Yes the main board controls the picture that is sent to the t-con including the refresh rate but the t-con controls the constant refreshing of the screen and motion flow processing so they might have told you something but got it confused with something else. There's definitely something going on with that t-con board.
              quick question is the motion smeared on both sides of the screen or is it more on one side it doesn't seem darker on one side of the screen?
              • Alastair E
                Chief Womble
                • Mar 2013
                • 1963
                • U.K.
                Seen a few various sets with this slow refresh image retention effect...
                It was the panel itself in the ones I had--replacing T-con did nothing to the fault...
                TELEFIX
                • nittamk
                  • Nov 2014
                  • 10
                  Just reinserted the main board. The motion seems smeared uniformly across the entire screen. The only clear images are the parts that don't move, like the score of the hockey game. I have photo but don't know how to post to this thread. Failed to mention earlier that the initial power on screen is full of white vertical lines that go away once program video frames start.
                  Tested as many fuses on the main board as I could identify, all seemed good. Some were really small, been a long time since I worked on a PC board.
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    I'm still 99.5 percent confident that it's your T CON board still .I've been dealing with Sony's and tcon problems the last couple months. its most likely a processor issue somewhere located within the phase loop lock portion of the processor for motion flow. I've come to the conclusion on my board that the processors faulty. I've spent too much time on these boards trying to figure out why so I've come to the conclusion that it is the same problem on three of my sony lcd tVsall of them have the motion blur that you're talking about. I do have one good bored and I've tried it in all three TVs and the problem was cured.so that's why I'm confident that if its uniformly blurry across the screen and you did blow fuse on your T CON that is the problem. this problem presents itself in the same fashion as a bad connection problem in the panel but the only difference is that when you have a bad connection on one of the ribbons going into the panel itself usually it presents itself with the screen non-uniform and smearing and darkon half usually either the right or the left side but since this problem is all the way across the screen it is not a panel issue but more at con board motion flow problem
                    • nomoresonys
                      • 12331
                      • U.S.
                      I'd try a tcon first, since they are the cheapest, sometimes 10-30 bucks.
                      • nittamk
                        • Nov 2014
                        • 10
                        I'll start looking for a T-con.
                        Thanks everyone. Will update when I get some results.
                        I'm curious, can I get a new processor and change that on the T-con board? The last time I really played with electronics, there were tubes in the TVs.
                        • nittamk
                          • Nov 2014
                          • 10
                          Retract my curiosity. I just took a close look at the two bigger processors and looks impossible to remove let alone reinstall. So, dumb question.
                          Also my comment on "tubes" seems out of place, I did some googling of "freakaftr8", it seems that you young guys (I'm more than twice your age) are really into old electronics. An RCA CTC-11? Really?
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            Yea that's one of my other hobbies. Lol. I fully restored an RCA CTC-16 a few years back and had performed cataract surgery on badly deteriorated PVA material that they put over the round color 21FJP22 CRT if you remember seeing how you get the halo effect on some of these screens well it turned out perfect and I donated it the TV to an antique Emporium for display. after recap the power section and some minor tweaks and new tubes I got that sucker looking pretty good. I'm a pro now at convergence. sitting with me here at home I have also a Sony KV 3000 R very rare TV made of tamo ash wood with folding electronic tambou doors. That one needed some work in the high-voltage section including a horizontal output transistor. Got it from Hollywood and was told it was somebody's TV that was famous but you know how that goes. Lol
                            • nittamk
                              • Nov 2014
                              • 10
                              Update: Got a replacement t-con today, installed and it .......WORKS!!!
                              No more slow motion. Everything seems good.
                              Got t-con from Tri-State Module Inc total $48. Probably could have found a lower price but ran into a lot of "out of stock", TSM said they have about a half dozen in stock, ordered on 12/29 so came pretty quick.
                              THANKS EVERYONE, FOR ALL THE HELP!!!.
                              Just started working on my cinemin swivel projector, it has thousands of black dots and wowwee is not supporting it any more, will create a new post soon.
                              • steves7839
                                • Nov 2014
                                • 200
                                I wish I could find a T-Con for my Sony. If anyone runs across a 55.46T02C05 or 55.46T03.C03 please let me know!
                                • killpatrick
                                  • Nov 2016
                                  • 40
                                  • Philippines
                                  There's lot of them in Ebay, purchased mine from ebay and it was okay.
                                  • Andrew F. Ali
                                    • Jan 2014
                                    • 2450
                                    • Trinidad & Tobago
                                    Slow motion smeared picture is loss of the VGON voltage on the T-CON Bd. However, this symptom can be manifested if there is loss of the VGON signal from X-Bd/Source Bd at the bottom of the Panel to the Y-Bd /Driver Bds at the side of the Panel....There is a 'Bypass Method' used to fix this issue.
                                    • Daveleone
                                      • Apr 2016
                                      • 267
                                      What is the bypass method? I have a Sony KDL46XBR6 that's doing the same thing.
                                      • CyberPhoenix
                                        Issue with picture quality of Sony bravia TV
                                        by CyberPhoenix
                                        Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                                        01-22-2024, 02:08 AM
                                      • noisykid
                                        Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                                        by noisykid
                                        5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                                        12-30-2024, 07:15 PM
                                      • iglitare
                                        Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                                        by iglitare
                                        i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                                        Backlight seems to work, Sound (Setup menu after reset) works.
                                        If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                                        Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                                        With my small knowledge i would think at least the cables are good.
                                        Can this happen because of a bad tcon board?
                                        Or is it always a bad/shorted...
                                        09-04-2025, 07:13 AM
                                      • tree5656
                                        diagnosing sony XBR-75X900H. NO PICTURE
                                        by tree5656
                                        This tv is not even 3 years old. its a sony XBR-75X900H, it was like a flashbang went off suddenly, tv faded to black and no picture. backlight is on. tried to do the power cycle, factory reset. i get beeps from remote if i tap up/down but no picture. how can i determine if its the panel or a board? i have replaced boards before im just not sure what the issue is here. sony said nothing they can do and only suggested to find a local repair shop. please guide me here
                                        11-09-2023, 04:55 PM
                                      • DKWS89
                                        Sony XBR 49x900E - Sound and backlight on but no picture
                                        by DKWS89
                                        Hey Guys,
                                        So a few months ago my Sony XBR 49x900e TV screen stopped displaying the picture but the backlight comes on and I still get sound when I use the remote and navigate to certain apps. I haven't checked anything with the meter yet but started with ordering some replacement boards. I've tried replacing the BMKS board (used from ebay) and also completed the firmware upgrade based on Nicks TV repairs youtube video. I've also replaced the TCON (twice) and PIB.
                                        All of these changes have resulted in the same issue with no picture. I've also tried disconnecting the ribbons...
                                        12-14-2023, 04:30 PM
