Vizio VX42L Back Cover Screws
  • Herbssat
    • Sep 2011
    • 194
    Hi guys. I currently have this set that i have repaired with no back cover screws. I think that there are about 21 of them. Need a screw size so i can put it back together. Thanks.
  • Herbssat
    • Sep 2011
    • 194
    Re: Vizio VX42L Back Cover Screws
    Going to answer my own question here. I called vizio support earlier and they told me 4x8mm. Hope this helps someone with a weird situation like this.
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
    • mrdevil
      Crest Smart Home Single Power Adaptor SHSPM1 (rebadged Tuya device) - bad cap causing failure, how to repair
      by mrdevil
      Wanted to share this as I couldn't find anything on the internet about this problem, so pulled one apart and found the problem myself. Years ago I bought approx 20 or so Crest Smart Home Single Power Adapter smart switches - small 240v Tuya-compatible (rebranded) smart switch devices with power monitoring, which Big W had on sale for half price. Paid $7.50 each for these, and they've been incredibly useful for turning things on and off remotely... and monitoring how much power each device uses.
      However, after about 12 months, I had a number of these stop working...
      01-08-2025, 03:19 AM
      Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
      This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
      I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
      I am comparing them to a brand new one that I installed
      The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
      I going to let it run for several days before I remount back on the wall next to the...
      09-05-2024, 06:48 PM
    • NolesFan
      sony kd-85x85j Looking for info on how to remove back cover
      by NolesFan
      Like the title states. TV is 3 years old and Im getting 6 red blinks, which is backing lighting issue or driver. I just cant find any info on how to remove the panel to access. Any info would be greatly appreciated.
      03-14-2025, 08:23 PM
      by momaka
      03-15-2023, 10:17 PM
