LG Plasma fuse blown.
  • Scottmac
    • Nov 2014
    G'day to all from the top end of Australia. First post, I hope somebody can give me some advice.
    My TV died last night. It is an LG 50PT250 Plasma. I have traced the problem to a fuse on the PSU card. The fuse is a 5A soldered into the card.
    Can't see any other burnt out or damaged components on any of the cards.
    Where can I source another fuse to suit?
    Do they blow for no reason occasionally, or is it likely there will be further problems down the line?
    I have sourced a new PSU board on eBay for 80 bucks, should I just get that?
    Also when I checked for voltage at the outlet it was 250v. Shouldn't be that high.Nominal voltage here is 240Vac. (I'm an electrician). It was checked on a cheap meter I keep in my boat, so maybe not real accurate.
    Is 250vac high enough to start damaging electronic components?
    Cheers for any advice, Scotty.
    Re: LG Plasma fuse blown.
    Fuses -rarely- blow without obvious cause. That's not to say it doesn't happen, but it is very rare.
    You can try testing some other parts if you have a multimeter. Otherwise replacing the power board ought to fix the fault.
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Perhaps the battery is going in your meter - that might account for the 250v reading.
        250V is ok for most 230V devices, including TVs. Up to 253V is ok in a 230V/240V nominal country, devices are tested to 265V.
        • Scottmac
          • Nov 2014
          Thanks for the replies guys. I have ordered the new PSU and will check out the old one as time allows, although there isn't any obvious damage to the caps etc.
          • Babbar
            by Babbar
            04-12-2024, 01:12 AM
          • drscoot
            HP X360 convertible battery blown fuse error, not charging
            by drscoot
            HP Modelnumber: 14-dh0061nb​
            This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
            The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
            I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
            And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
            All these 3 batteries are charging...
            12-15-2023, 05:54 AM
          • beetle1303
            Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
            by beetle1303
            I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
            On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
            01-13-2025, 08:49 PM
          • jesterace
            Samsung UE46ES8000 Blown fuse but no other signs of short
            by jesterace
            Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
            09-11-2024, 03:14 PM
          • whc14765
            Gigabyte 980TI Windforce - Blown PCIE Fuse
            by whc14765
            Hey,
            I have a Gigabyte 980TI Windforce. No shorts on the main 8 pin PCIE power connectors. The 8 phase buck converter inductors are showing 2.5ohms.
            The card doesn't power up at all - no lights, no fans, nothing. I noticed that all of the 8 phase inductors are showing 0V. I couldn't find a fuse for the 8pin power connectors.
            I did notice that the PCIE x16 connector 12V line has a fuse F3 (10A marked on it) which is blown. It is reading 16ohms on one end.
            1st Question: Is there some logic on the board that checks the 12V on the PCIE x16 bus connector...
            04-08-2022, 06:22 PM
