Re: Sony Bravia KDL-46S4100
"Any one know if a upgrade for a kdl-46w4100 will work on my main board?" so did you use the kdl-46w4100 firmware (http://esupport.sony.com/US/p/model-...d#/downloadTab) or you found the 46s4100 firmware (not on SONY web site).
Do you have the link for download? Thanks.
I found the instructions:
The firmware is---The latest version is KDL_S4100_V1.115Leave a comment:
The TV works now did a firmware reset, and all is good.Leave a comment:
I have 2 main boards n 3 tcons, 2 of the tcons give me baclklight when bl-on is unplugged solid color and the 3rd tcon gives me what looks like the age pattern when bl-on is unplugged, but nothing on all three when bl-on is plugged in, not even a menu, so I guess I ether got 2 bad main boards or I need to restore the firmware, why sony has no firmware on their site for these is a mystery to me. checked all the plugs on g board, they seem good.Leave a comment:
LOL, I hear that I'm about to toss this one off a bridge.Leave a comment:
No luck I am going to try a KDL-46w4100 firmware upgrade . I'll post when I get it done. I have like 6 TVs in front of this one . Whats the worst that can happen I still wont work? Oh well.Leave a comment:
My Son brought this set to me for fixing. After reading all there was on the internet . It needed a new a- board (main board). I ordered a exact matching number board . The set powers on now,but it is stuck in a test pattern that cycles. The remote only turns the set on or off. I checked Sony for a software download but it came up no software for this model. Is there somewhere I can get a complete firmware download for this set. Any help would be appreciated.Leave a comment:
Any one know if a upgrade for a kdl-46w4100 will work on my main board?Leave a comment:
My Son brought this set to me for fixing. After reading all there was on the internet . It needed a new a- board (main board). I ordered a exact matching number board . The set powers on now,but it is stuck in a test pattern that cycles. The remote only turns the set on or off. I checked Sony for a software download but it came up no software for this model. Is there somewhere I can get a complete firmware download for this set. Any help would be appreciated.Tags: None
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by jb_BakHey guys great forum glad to have found it. I bought a Sony XBR 65X900C cheaply because it didn't work. No signs of life at all not even a light/led. All I hear is a brief high voltage sound when I throw the power to it.
CN6401
Pin 01 NC
Pin 02 NC
Pin 03 "BL_ON": 0V
Pin 04 "N/C"
Pin 05 "STBY 3.3V": 3.5V
Pin 06 "GND": N/C
Pin 07 "AC_OFF"... -
by eclectricHi, I'm hoping someone can help me with this issue before I give up on this TV.
In short, I replaced the T-CON board due to an error code indicating that was the problem, after which it flashed a green and orange LED meaning software update required. I cannot get the tv to do the required update via USB, so I am stuck.
Here is a rundown of the symptoms and the steps I have taken to troubleshoot:
I inherited the TV with the symptom that it would turn on, then turn off after 5-10 seconds and a red LED flashed 4 or 5 times. Sometimes it would be 4, sometimes... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
- Loading...
