Zenith Z42PJ240 - Turns off when trying to change input
  • tucocaps
    • Apr 2013
    • 331
    • United Stated
    This is a cracked/damaged set that I have been planning on either trashing or pulling parts off.
    Of course, no picture, since screen is totally cracked. The set will turn on, and I've programmed a remote , and used the console buttons, but no matter how I try to change input, I just see a red flash on the power led, and the set appears to shutdown.
    Could I be sure at least the power supply is OK with these symptoms? Thanks for any ideas!
  • tucocaps
    • Apr 2013
    • 331
    • United Stated
    Re: Zenith Z42PJ240 - Turns off when trying to change input
    Any ideas on this one? I'm guess mainboard, but power board is likely ok, since it will stay powered on , until i change input?
    • tucocaps
      • Apr 2013
      • 331
      • United Stated
      Thought I'd ask once more if anyone has an idea on this. Hate to throw the entire set away if some of the parts can be salvaged. Just not sure what would cause the power off when changing input via remote.
      • ugamazing
        820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
        by ugamazing
        So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
        1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
        2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
        04-10-2024, 08:06 AM
      • Stephen
        MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
        by Stephen
        MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
        03-15-2024, 09:37 AM
      • www
        LG L192WS-BN backlight turns off after 1 second
        by www
        I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
        I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
        03-24-2024, 05:26 PM
      • zklgfs
        Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
        by zklgfs
        I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
        08-11-2025, 02:14 PM
      • andrhouseolly
        Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
        by andrhouseolly
        Hi.
        I kindly ask you to help me solve the problem.
        Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
        The board turns on, there is no image.
        Read more. When the power supply is connected, the front panel indicators light up briefly.
        When you press the power button, the button indicator lights up. The board works
        there is no image, there is no matrix initialization, there is no image on HDMI.
        When turned on, the fans do not spin, but when they warm up they start spinning.
        When you turn off the button, the fans spin up to full speed for a short...
        05-11-2024, 03:14 PM
