Lg 50ps3000
  • finntricky
    • Jan 2014
    • 449
    Re: Lg 50ps3000
    so, looks like an ebay job
      Re: Lg 50ps3000
      I'd consider the possibility of a missing drive signal on the Y-sustain, or a signal between the buffers going missing.
      Shame you're not closer to me, or I'd have it off you
      • finntricky
        • Jan 2014
        • 449
        Re: Lg 50ps3000
        back on this again, TOM, because you said drive signal, thought i'd have a check on the cables.
        on checking the ribbon cables from Y_SUS to top buffer, pulled it out and the cable has some damage to the tracks, some broken, and even some bits missing.
        so my question is, where can i get new replacements ?
        tryed to cut the old ones back a bit, but then there is not enough contact, and can't peel the back off to reveal or make longer contacts.
          Re: Lg 50ps3000
          Probably the only place is a TV breaker who might have kept the cables. They are custom and very expensive in low quantities... I've had the same issue on an LG DVD player so wonder if it's a common issue with LG's cable supplier. In my case the metal contacts just broke off completely and wedged themselves in the connector.
          • Loretto
            Samsung SMPS BN44-00339A
            by Loretto
            this unit comes from a samsumg LCD TV LE32C530F1W which stopped working after making a strong noise like something was exploded inside of it.
            I opened it and found that fuse FP801S was blown, capacitor CP814 was completely disintegrated and MOSFET QP801S was shorted.
            I replaced all of them and instead of the fuse I connected a 100 Watt bulb. Then, without connecting it to other TV boards, I switched it on, but the bulb begun to blink.
            I thought that maybe the bulb was somehow interfering with the normal operation of the power supply, so I replaced it with a fuse,...
            03-29-2025, 08:30 AM
          • Loretto
            by Loretto
            03-28-2025, 10:28 AM
          • Formaster
            Sony KD75XE9005 Bottom half double image
            by Formaster
            Hi guys,
            I'm tyred from these sympthom, if anyone helps me really big thx.
            When i open the connection and play with these ribbon cables, i can get back the image problem free. BUT after turn off and ON, the bottom half is ghosted/doubled again. Did'nt from touch, only reboot the TV. I have changed the ribbons from the other side, but the same. Anyone any idea please?...
            08-10-2021, 06:57 AM
          • MisterAIL
            PS5 digital / No Power / No Beep / Good power supply
            by MisterAIL
            Brought a non functionnal PS5. Apparently only a bad PSU...
            No beep, nothing.
            After some tests i found this :
            - PSU is fine (12 volts stable)
            - 12 volts line is shorted
            - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
            - By the way, nothing change. No signal, no power, no beep.
            Mesuring all rails with my workbench psu (12 volts input)
            - 0.00 amp drawing
            - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
            03-12-2024, 03:24 PM
          • Raulnn
            TD Systems K50DLG12US half black and half white screen
            by Raulnn
            good night! I have this screen that looks half black and half white. the tcon gives a low vgh value (5-6v). the rest seem fine. I first removed the flex from one half of the panel and then the other. Removing the left, vgh increases it to 25-26v. I think the problem is in that area, but there are not many elements on the integrated controller board. there are no shorted capacitors. could they be a cof? Some help?
            By the way, now the entire screen is black. Maybe some flex was not connected correctly... I have exchanged the flex and there are no variations, I don't think they are the...
            01-20-2024, 04:49 PM
