Dynex DX-L42-10A Picture - Weird Colors
  • barryra
    • Aug 2013
    • 107
    I read some of the same picture issues this TV was having & am pretty sure I need the tcon board repair kit (which is a chip with many connectors) Shopjimmy sells for $14.41
    My question is... is this pretty easy to take out & install? Do I use a regular solder iron? Thank you
  • splitcrete
    • Dec 2012
    • 387
    • usa
    Re: Dynex DX-L42-10A Picture - Weird Colors
    as15 chip Its a moderate to expert solder job, depending on the tools you have.
    • splitcrete
      • Dec 2012
      • 387
      • usa
      The first one I did i burnt the pads off.
      I did mine with a hot air station.
      Don't go over 600 deg. and use a lot of flux.
      I have read (Chip Quik) works well.
      When you solder the new one on watch
      for bridges across the pins of the chip.
      Search for AS15 and you will see some of
      peoples work.
      Good Luck.
      • splitcrete
        • Dec 2012
        • 387
        • usa
        Post a good focused picture of your T-CON board
        • diif
          • Feb 2014
          • 6978
          • England
          I've used both ChipQuik and hot air to remove the AS15.
          I attached the first pin, then an opposite corner, then carefully went along with my iron touching each leg.
          I then checked continuity with my multimeter on adjacent pins.
          • Moreno83
            • Jun 2014
            • 2008
            • The Netherlands
            You could also try to cut the pins with a small sharp knife. This way the chip will fall from the board Then with a small iron tip you can easily remove the rest of the pins on the board , works fine for me.
            • barryra
              • Aug 2013
              • 107
              I may try to install a new chip from Shopjimmy. This is something I haven't done before so I hope I don't butcher it...
              • barryra
                • Aug 2013
                • 107
                Would someone like to install a new chip on the t-con board for me if I mailed it to you?
                • splitcrete
                  • Dec 2012
                  • 387
                  • usa
                  Just do it if all goes wrong just get another t-con.
                  Its good to learn. Practice on an old board.
                  Cut the pins like Moreno83 said and you should be good to go.
                  Just remember don't go over 600 deg.
                  • splitcrete
                    • Dec 2012
                    • 387
                    • usa
                    I have a bunch of those chips . It was such a common problem
                    I ordered 10 of them,and only used 2.
                    • barryra
                      • Aug 2013
                      • 107
                      Get this.... I read that cleaning the connectors & the tcon board connections sometimes will fix this issue. It did!!! The TV was totally caked with dust & I used my air compressor to clean the big clumps. I then used canned air on the connectors... 91% rubbing alcohol with a-tips on the connectors & connections & then blew dry with canned air. It's been working great for the past 3 hours.
                      Thanks everyone for all your help.... with the other TV's also.
                      • Ierwin
                        Philips 58PUS7805 Menu working but no/weird picture from video sources
                        by Ierwin
                        I got a 58pus7805 that shows some weird behavior.
                        The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
                        However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
                        I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
                        I managed to install the latest official firmware by holding the control button while plugging...
                        03-10-2024, 12:50 PM
                      • Tr0ll
                        by Tr0ll
                        Original T-con:
                        First replacement T-con:
                        10-07-2023, 07:48 PM
                      • JJAAMM
                        by JJAAMM
                        Problem
                        07-06-2023, 06:01 AM
                      • TR103
                        by TR103
                        - it keeps rebooting
                        01-22-2025, 04:12 PM
                      • YellowJacket
                        Samsung QE55Q60RAT - no picture
                        by YellowJacket
                        Hi friends,
                        a friend of mine gave me this TV to fix, with common SAMSUNG TV issue - damaged panel. Turning on, sound is present, but no picture. So I went directly to standard process, connecting two pads together with a wire ( see in the picture ), and then removing flex cables. With right flex connected, there was half screen working, but still no picture ( disappearing colors and similar weird stuff ) + working sound. With left flex connected, TV is restarting + working sound. I supposed, left side is damaged, so I then blocked all 8 CLK pins ( going from 0R resistors on the second...
                        07-30-2024, 01:31 PM
