Samsung LN46A530 Display Issues
  • Skips69
    • Oct 2014
    • 11
    Hello everyone!
    New member, first time post. Ive been searching this and other sites hoping to find a solution to my TV problem.
    It started with a solarization issue, which led me to believe it was one or a combination of:
    A bad LVD connection. I checked the LVD connection and didnt find anything.
    Bad T-CON BOARD. I replaced the T-CON BOARD and this fixed the solarization issue. But then a seemingly new issue came up. See attached. I have vertical bands distorting the color?
    I thought it could be a bad LVD cable, so I replaced the LVD cable (with another used one). Still the same issue.
    Any suggestions or insight would really be appreciated!
  • Skips69
    • Oct 2014
    • 11
    Re: Samsung LN46A530 Display Issues
    Oh, and i forgot to add that i went into the service menu and did a factory reset. This did not help either.
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      I would first try and re-seat the ribbons from T-Con to the panel....
      --Do this ONLY while set is switched OFF.
      TELEFIX
        Could you try your set with the old T-con board (with the solarisation issue) and see how it responds?
        • Skips69
          • Oct 2014
          • 11
          Hello Tom!
          I tried the old T-CON board.
          Old T-con board is definitely bad.
          See attached photo. Solarization is back.
            Good, so in my mind this eliminates the panel and main board as a possibility, so your new T-con must have been bad. I'd contact the seller and arrange a return/refund.
            • Skips69
              • Oct 2014
              • 11
              I just tried this and am now back to the image shown in my first post.
              So is the consensus that the new T-CON board is defective?
                Yes... Both T-cons are defective.
                Your replacement fixed the solarisation issue - but brought with it another issue.
                To be honest, if I saw that, I would have said bad panel - so I am quite surprised.
                • Skips69
                  • Oct 2014
                  • 11
                  Thanks again, Tom.
                  Ill return the new T-CON board and hope another one fixes the problem.
                  • Skips69
                    • Oct 2014
                    • 11
                    Returned the T-CON board and now they told me they're all out. Does anyone have a recommendation for a reputable supplier that I could order from?
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      whats the numbers from the t con board
                      • Skips69
                        • Oct 2014
                        • 11
                        T460hw02, 06a83-1a
                          What are the numbers on the barcode sticker, that is the PCB assembly part number which blank board is stuffed with parts for the needed assmbly. Same blank board can be stuffed to create more than one type of assemblies.
                          Did you check shopjimmy.com?
                          http://www.shopjimmy.com/catalogsear...msung+LN46A530
                          Is this the one?
                          http://www.shopjimmy.com/auo-55-46t0...-con-board.htm
                          • Skips69
                            • Oct 2014
                            • 11
                            Shopjimmy is the company that sent me the defective replacement board, they do not have any more available.
                            • Skips69
                              • Oct 2014
                              • 11
                              Here's the barcode on the board. Still looking for a supplier! Shopjimmy tells me they're out of stock.
                              Thanks in advance for the replies!
                              • Kjell
                                Samsung Series 9 - BIOS issue
                                by Kjell
                                After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                                Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                                08-01-2025, 09:15 AM
                                09-07-2024, 05:50 AM
                              • Nairolf
                                Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                                by Nairolf
                                I have a Samsung DM32D display.
                                When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                                Here’s what I have tried so far:
                                1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                                2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                                3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                                From these tests, I suspect the problem might be on the mainboard. Could anyone...
                                08-24-2025, 03:47 AM
                              • vincentedel
                                Samsung SyncMaster 740n Phase Control Issue
                                by vincentedel
                                I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                                I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                                04-22-2025, 12:33 AM
                              • Manucsl
                                QE65Q800TATXXC Samsung TV Issue
                                by Manucsl
                                Hello.
                                My TV is a QE65Q800TATXXC Samsung TV.
                                Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
                                Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
                                Any ideas to check would be very appreciated 😊
                                After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
                                02-19-2025, 07:47 AM
