Samsung PN43D450A2D, screen vertical line, flickering
  • taeyang999
    • Oct 2014
    • 4
    I have three years old samsung 43" plasma tv that was connected to my security system using RCA.
    One day, I turn on the tv and it is showing like the picture I attached.
    So far, I did factory reset, upgraded newest firmware. Nothing fixed.
    I need help fixing my tv. I really appreciate for your help.
  • Clydeuk
    • Jan 2012
    • 193
    Re: Samsung PN43D450A2D, screen vertical line, flickering
    I would guess CTRL board needs replacing.
    • taeyang999
      • Oct 2014
      • 4
      Do you know part# and where I can order?
      • Clydeuk
        • Jan 2012
        • 193
        Best to get the part number off the board itself. It's the small PCB in the lower middle of the screen below the power supply, will have ribbon cables connecting to the Y main (left side looking from the back) and the lower buffer boards, and one connecting to the main board (the one with the inputs on).
        It's a guess but it looks like a classic CTRL board type failure.
        • mrsith
          Samsung UE58TU7100K - no picture, vertical line
          by mrsith
          Hi.
          Got UE58TU7100K with no picture - backlight comes on though. Figured out that's a perfect candidate for cut tape method.
          This model has just one LVDS tape coming off main board - and two panel boards underneath the LCD screen are connected to each other via small tape. Like curved screens. I've tried to disconnect half of the screen (5he side without LVDS connector on it, obviously), no joy.
          Disconnected the tape (main board side). Applied a small piece of tape, covering first ~4-5 pins. Powered the TV on - got picture. In negative, but that's...
          02-07-2023, 11:18 AM
          09-07-2024, 05:50 AM
        • kotel studios
          Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
          by kotel studios
          Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
          In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
          08-06-2025, 02:07 AM
        • otaku_nut
          Vizio E701i-A3 fixed but now has red vertical line
          by otaku_nut
          Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
          08-19-2025, 06:11 PM
        • sputnikoff
          samsung un58tu7050 single vertical line.
          by sputnikoff
          Had a friend drop this tv off and initial issue was no power.I could see faint glow when powered up .Lamps all fired up fine.I removed flat lvds cable and reseated it,then tv screen came on.After i reassembled it now has single line pretty well dead center of screen.Is there ongoing display issues anyone is aware of.Any input welcome.
          02-25-2023, 09:42 AM
