Need help with Samsung HPR4272
  • adam699
    • Nov 2011
    • 16
    So I got the TV with no picture but sound. After some investigating I figured out that the lower Y buffer shorted and burned out the lj92-01200a Y-sus board.
    I changed the IPM, a shorted Mosfet, two resistors and one diode and the faulty buffer board as per other threads on the subject and got up to this point and now I'm stuck seeking advice.
    The voltages specified on plasma panel all check out when probing test points.
    I get a distorted picture as on the photo. The menu appears way better than rest.
    Please advise what to look at next.
  • adam699
    • Nov 2011
    • 16
    Re: Need help with Samsung HPR4272
    Picture #2
    • adam699
      • Nov 2011
      • 16
      Picture #3
      • kasfamily
        • Aug 2014
        • 769
        • Russia
        What values Vs,Va,Vset,Ve,Vscan ?
        • ERICSSON89
          • Oct 2014
          • 46
          • NIGERIA
          upload pictures of ur PSU both front and back, mainboard and TCON board. your TCON board might be the culprit.
          • mmartell
            • Oct 2013
            • 3189
            Try unplugging xmain and see if pic still looks the same.
            • mmartell
              • Oct 2013
              • 3189
              According to the first post this is a plasma not an lcd.
              • adam699
                • Nov 2011
                • 16
                The sticker on the panel says:
                Va: 70
                Vsc: -190
                Vs: 205
                Ve: 82
                VSet: 195
                When i probe it:
                Vs: 191
                Va: 68
                Vset: 196
                Ve: 82
                Vscan: -191
                • adam699
                  • Nov 2011
                  • 16
                  This is what I get when I unplug the xmain
                  • mmartell
                    • Oct 2013
                    • 3189
                    To my untrained eye it still looks like a xmain problem. Try measuring Vbias on the xmain.
                    • adam699
                      • Nov 2011
                      • 16
                      I don't see a test point for Vbias. How do I measure that?
                      Also the picture looks more normal when there is no signal.
                        Vbias = Vzbias, same as Ve.
                        It's hard to tell what board is at fault... do you have an oscilloscope or can you borrow one? The Y-main and X-main output waveforms can be checked, if you have one available.
                        • adam699
                          • Nov 2011
                          • 16
                          Like an old school osciloscope? My father might have one, I'll check if he does.
                          Is there some PC based osciloscope software I could use?
                            I wouldn't use a PC scope for a plasma panel, the sustain voltage is too high for most of them (peak 400V amplitude!)
                            If you can borrow a scope that would help greatly - try to get a 10X probe with it too...
                            • adam699
                              • Nov 2011
                              • 16
                              No go on the scope. I don't really have anyone that I could borrow it from. What am I looking for? I searched on ebay but it seems like there might be different ones for different pourpose.
                              • adam699
                                • Nov 2011
                                • 16
                                Well, I risked it and ordered a working Ysus board and all is well now in case anyone cares
                                  09-07-2024, 05:50 AM
                                • TR103
                                  by TR103
                                  - it keeps rebooting
                                  01-22-2025, 04:12 PM
                                • JJAAMM
                                  by JJAAMM
                                  Problem
                                  07-06-2023, 06:01 AM
                                • Mgiffune
                                  by Mgiffune
                                  I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
                                  I ordered a supposedly β€˜new' Tcon board this time, and
                                  06-09-2024, 10:28 AM
                                • Dodgethis
                                  Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                  by Dodgethis
                                  Hello all,
                                  This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                  09-11-2024, 07:39 AM
