Samsung LN46A650 - No video, audio and backlight ok
  • Arkadi_73
    • Oct 2014
    Hi Badcaps experts
    I'm having an issue with my Samsung LN46A650 and was hoping that someone might be able to help me out with a little guidance. My tv (LCD) has audio and backlight, but no picture. I don't have a multimeter, so I haven't been able to do any component testing.
    For a few months my TV would, on occasion, start displaying some horizontal green/pink lines, which would eventually take over the whole image. This would generally go away after 15 mins or so. Now the TV turns on ok, but there is no video at all, I can't even see the input changes, volume adjust, etc, but they do work.
    Based on a lot of reading online, and a little guessing, I thought it was the T-Con board. However, I purchased one (used) online, switched them out, and no change. I had checked the capacitors on the power supply, and checked them again, but there is no obvious evidence (oozing or bulging) that any are bad. It does seem to be a weakness on this model from what I have read.
    In light of this, does it seem to be a main board issue, could the caps all look good, but still be the reason? Would a bad panel behave like this? (I really hope not). I realize I'm not giving you much to go on, please tell me what info you need and I'll do my best, if you are willing to help me out of course.
    Thanks to any replies,
    Arkadi
    Re: Samsung LN46A650 - No video, audio and backlight ok
    Pictures of the screen shot, the whole back side of the TV will be a good start.
    • JudgeLaurier
      • Oct 2015
      I am having the same problem - did anyone come up with any solutions - Larry
      Originally posted by Arkadi_73
      Hi Badcaps experts
      Arkadi
      • mmartell
        • Oct 2013
        • 3189
        Try heating the main board with a hair dryer for 30 seconds to see if the symptoms go away or get worse. You could try freeze spray as well. Sounds to me like main board has bad solder joints somewhere.
        • tvtimmy
          • Mar 2015
          • 1160
          • usa
          I just got done fixing one of these. It was the t con board. Lucky I had a spare.
          • SolarFlare
            Mi TV 4 Pro-Samsung Panel LSC550FN20 - Video problem, backlight and Audio works fine.
            by SolarFlare
            My barely 3 year old TV has stopped displaying video, although the video output comes for a few seconds after turning ON which displays the manufacturers logo then shows the home screen (all this with some blue flicker) then the video goes blank and the screen is dark blue with the backlight on. The audio output works perfectly and the TV also takes in voice commands(smart TV).
            The TCON board has the following Chips -
            Samsung VTU63A0
            RT6939 - 2nos.
            and all these chips are getting real hot within a minute, I dont know if this is normal....
            06-26-2022, 08:58 AM
          • Max514
            Samsung UN55H8000 sound but no backlight no video
            by Max514
            Ok so I have this beautiful un55h8000 samsung tv with sound but no video nor backlight. When turning the set on the red light blinks 5 times.
            The screen shows no damage and backlight turns on when I disconnect the power supply from the main board. The tcon board only has 2 out of 3 leds on.
            I came across this page and followed the different steps: https://techhometravel.com/samsung-u...ight-no-video/
            • Unplugging the main board cable at the power supply >>> backlights came on.
            • BLU_ON signal from the
            04-14-2022, 10:34 AM
          • C152Heavy
            Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
            by C152Heavy
            Summary for TL-DR readers:
            • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
            • Have obtained Samsung schematic & service documents - Can upload if helpful.
            • Have read ALL applicable threads
            • C1818 and CP820 replaced as low hanging fruit
            • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
            • VCC pin (18) of PFC...
            01-11-2023, 02:53 PM
          • samson7point1@yahoo.com
            Help troubleshooting an audio problem with an RCA SGT-250 CED Player
            by samson7point1@yahoo.com
            The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
            The player processes the audio signal using two different reference frequencies. The "R"...
            04-30-2024, 11:22 AM
          • alro7779
            Samsung UN55MU6103F video problem; has colored stripes on the display
            by alro7779
            Hello, everyone!
            A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
            09-27-2025, 11:29 PM
