Coby LED TV2326 - No Power
  • ltaylor728
    • Oct 2014
    • 18
    My first time doing this...My Coby LED TV2326 will not power on, no stand by, no clicking, nothing. I took the power supply board to a tv repair guy who tested it and said nothing was wrong with it, that it must be something else, and that I should stop wasting my time and buy another tv. The frugality in me figures I've nothing to loose by still trying to fix it.
    I've attached various angled views of the motherboard (part no. 002-FV24-2510-00R). There are lots of questionable yellowish-brownish ooze. Not sure if I should replace.
    Please save me someone!
    Re: Coby LED TV2326 - No Power
    Please upload the pictures of the whole back side of the TV so we can see how all the boards are connected together, and also good whole pictures of the power supply board top side and bottom side of the board.
    BTW, those yellowish stuff are bad brown glue that will become corrosive and conductive.
    Did you check the voltage outputs of the power supply board to see what it is putting out?
    • ltaylor728
      • Oct 2014
      • 18
      Here are more pics.
      Don't know about voltage output (sorry). TV repair guy checked voltage ouput on various components on the power supply, but not sure exactly what, just know he said nothing was wrong with it.
        So do you have digital meter, soldering iron, etc.?
        • ltaylor728
          • Oct 2014
          • 18
          No tools, but getting what i need is no problem.
            You will need at least a digital multimeter.
            • ltaylor728
              • Oct 2014
              • 18
              I got the meter!
                OK, do you know how to use it?
                See this photo:
                https://www.badcaps.net/forum/attach...2&d=1413991468
                Check the power outputs on the power supply, with everything connected. You should get some output voltages on the pins marked 12V and 5V. Careful, as the set will have to be live and plugged in while you do this... don't touch anything on the power board with your hands.
                To test: set your meter to 20V DC, put the black probe on a pin marked GND, and the red probe on the other pins one after another, noting voltages and the label they correspond to. Please present results like so:
                12V - 11.98
                ON/OFF - 3V
                GND - 0V
                ... (etc)
                • ltaylor728
                  • Oct 2014
                  • 18
                  The results:
                  PIN1.4.5:GND
                  PIN2:ADJ - "5.03"
                  PIN3:ENA - no reading
                  PIN6:7.5v - "5.23"
                  PIN8.9:12v - "12.5", "12.66"
                  Sorry for late reply, I've been very ill.
                    "PIN3:ENA - no reading" OK, the main board is not sending the Enable signal.
                    • ltaylor728
                      • Oct 2014
                      • 18
                      What does that mean?
                        It means the power supply board is OK, but the main board is not OK.
                        • ltaylor728
                          • Oct 2014
                          • 18
                          Should I try replacing it or is there further testing I can do?
                            For 23" TV? If it is less than $30 then it may be worth it.
                            You can check the voltages of the regulator ICs.
                            • ltaylor728
                              • Oct 2014
                              • 18
                              I'll look into it, thank you!
                              • ltaylor728
                                • Oct 2014
                                • 18
                                Need help, I replaced the main board and hooked everything back up; maybe i did something wrong; all i get is a white screen, no sound, PLEASE HELP
                                  Check the LVDS cable is connected, it's the cable between the main board and T-con board.
                                  • ltaylor728
                                    • Oct 2014
                                    • 18
                                    This cable? It kept coming out.
                                      There's a little black plastic latch on that connector. Usually you have to lift or slide that latch (be *VERY* careful, as they are delicate) to get the connector in properly.
                                      • PantherDave
                                        by PantherDave
                                        Hi all!
                                        05-29-2024, 02:01 PM
                                      • GLISIT
                                        by GLISIT
                                        01-16-2025, 02:29 PM
                                        by sam_sam_sam
                                        03-31-2024, 02:12 PM
                                        09-06-2024, 05:59 AM
