Sanyo Tv AVP4232 ,Power board not working
  • rod.wa
    • Aug 2014
    • 5
    Hello my name is Rod.. i have a 2008 Sanyo Tv AVP4232 , the power board keeps blowing out a 7 pin Transistor . my tv repairman cant find the problem? with three attempts all burn out. Any help would be helpfull...
  • Caleb
    Smokin IC's
    • Feb 2013
    • 645
    Re: Power board not working
    Most likely a short beyond overloading the chip, adding the service manual below hopefully it will help you out
    Liberating magic smoke one part at a time
    • Plaf70
      • Dec 2020
      • 9
      • canada
      Hello, I have a similar Sanyo television but the power supply diagram does not match mine. Mine would be XI6HA01820A4.
      Can anyone help me find this schematic?
      • lotas
        • Jan 2016
        • 4655
        • Russia
        Something like this model "XI6HA01820A4" even Google does not know.
          • 12206
          • U.S.
          well what are your symptoms, maybe we can muddle thru without a schemo.
          • Plaf70
            • Dec 2020
            • 9
            • canada
            A small capacitor is burned. I can't read its value. In the diagram shared here these parts are missing.
            When the television is on, I get no values at the x-sus and y-sus outputs. I suspect the IGBT MR4030. On the MR4030 datasheet I found that the capacitor value would be between 820pf and 2200pf.
              • 12206
              • U.S.
              test that igbt for shorts, test the rest of them too.
                • 12206
                • U.S.
                these old plasmas are getting more expensive to fix every day as the replacement boards become scarcer.
                  • 12206
                  • U.S.
                  the last one I worked on was a real pain in the ass, after fixing all the igbt's on the x board and a diode and replacing numerous caps, I found both y-buffer boards shorted and called it quits, honestly its only 720p, about any led lit tv you get a hold of will give you a better quality picture, its 720 vs 1080 or 4k. I would stay away from the off off brands, from recent reviews the hisesnse, tcl, seem to get pretty good reviews for a budget tv.
                    • 12206
                    • U.S.
                    plasmas may have had a great picture in their day, theres a very good reason they quit making them, just not great engineering imo, they run hot and heat kills, plus they're big time energy hogs.
                    • Plaf70
                      • Dec 2020
                      • 9
                      • canada
                      I appreciate and agree with your comment on plasma tvs. Thanks a lot.
                      She's going to end up in the recovery center.
                      • Dani_2024
                        by Dani_2024
                        10-28-2024, 05:06 PM
                      • JDC
                        (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                        by JDC
                        ONN 100012588
                        Issue: No Power, Then Rebooting After Main Board Change
                        Short answer: replace main board and power board
                        Technical answer: replace main board and Q306 & Q307 on power board.
                        Long answer:
                        TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                        07-15-2022, 07:39 AM
                        Tankless hot water heater controller board not powering up when power is applied
                        by sam_sam_sam
                        I recently bought a used tankless hot water heater and the controller board is completely dead no power up when power is applied the display board works however the main controller board does not work correctly at all the fuse is good
                        I bought a used replacement controller board that also had issues that I was able to fix and now the tankless water heater works correctly now
                        However I would like to know if I could figure what happened to this controller board if possible
                        Tomorrow I will take some better pictures of both side of both boards
                        The...
                        12-09-2022, 09:14 PM
                      • Rayblaster
                        HP RP7 RP7800 from 2012/2013 worst fault - has "character"
                        by Rayblaster
                        Hello friends, I've got a nice toy to play with - it is an HP RP7800 All-in-one POS system. I got it for free and it has one problem - it turns on very rarely, and just for a few seconds. After that it dies and doesn't come on if I don't leave it unplugged for at least 2 hours. I've repaired motherboards before, this is not my first one, but problem with these types of faults is that everything you check on the board will usually be fine. This is the case for me here.
                        I dissassembled it completely, and got my hands on the motherboard. Model No. is PIQ67H/Higgins 11047-I 48.3GD02.011....
                        12-30-2024, 06:28 PM
