Sanyo Tv AVP4232 ,Power board not working
  • rod.wa
    • Aug 2014
    • 5
    Hello my name is Rod.. i have a 2008 Sanyo Tv AVP4232 , the power board keeps blowing out a 7 pin Transistor . my tv repairman cant find the problem? with three attempts all burn out. Any help would be helpfull...
  • Caleb
    Smokin IC's
    • Feb 2013
    • 645
    Re: Power board not working
    Most likely a short beyond overloading the chip, adding the service manual below hopefully it will help you out
    Liberating magic smoke one part at a time
    • Plaf70
      • Dec 2020
      • 9
      • canada
      Hello, I have a similar Sanyo television but the power supply diagram does not match mine. Mine would be XI6HA01820A4.
      Can anyone help me find this schematic?
      • lotas
        • Jan 2016
        • 4919
        • Russia
        Something like this model "XI6HA01820A4" even Google does not know.
        • nomoresonys
          • 12323
          • U.S.
          well what are your symptoms, maybe we can muddle thru without a schemo.
          • Plaf70
            • Dec 2020
            • 9
            • canada
            A small capacitor is burned. I can't read its value. In the diagram shared here these parts are missing.
            When the television is on, I get no values at the x-sus and y-sus outputs. I suspect the IGBT MR4030. On the MR4030 datasheet I found that the capacitor value would be between 820pf and 2200pf.
            • nomoresonys
              • 12323
              • U.S.
              test that igbt for shorts, test the rest of them too.
              • nomoresonys
                • 12323
                • U.S.
                these old plasmas are getting more expensive to fix every day as the replacement boards become scarcer.
                • nomoresonys
                  • 12323
                  • U.S.
                  the last one I worked on was a real pain in the ass, after fixing all the igbt's on the x board and a diode and replacing numerous caps, I found both y-buffer boards shorted and called it quits, honestly its only 720p, about any led lit tv you get a hold of will give you a better quality picture, its 720 vs 1080 or 4k. I would stay away from the off off brands, from recent reviews the hisesnse, tcl, seem to get pretty good reviews for a budget tv.
                  • nomoresonys
                    • 12323
                    • U.S.
                    plasmas may have had a great picture in their day, theres a very good reason they quit making them, just not great engineering imo, they run hot and heat kills, plus they're big time energy hogs.
                    • Plaf70
                      • Dec 2020
                      • 9
                      • canada
                      I appreciate and agree with your comment on plasma tvs. Thanks a lot.
                      She's going to end up in the recovery center.
