Sanyo DP42841 won't turn on and Backlight
  • Ltank
    • Jun 2013
    • 776
    The TV had a Lightning surge. I can jumper on P.S. and turn on 24 and 12vdc. No backlight. How can I test backlight before buying a main board?
  • Ltank
    • Jun 2013
    • 776
    Re: Sanyo DP42841 won't turn on and Backlight
    JG1023 jumper has 2 wires to inverter pins 12 and 13 two black wires together
    • electronicsone
      • Apr 2015
      • usa
      hi tank, did you ever figure this out? I have the exact same tv with the exact same problem and would like to eliminate the psu by lighting the backlights. any information would be greatly appreciated. thank you
      • triplefour
        by triplefour
        09-13-2023, 10:43 PM
      • ovrax
        Philips 55PUS6804/12 turn on & off (probably backlight issue)
        by ovrax
        First of all, please excuse me as I'm quite new to this field.
        I have a Philips 55PUS6804/12 TV. It turns on and off instantly (backlight flash). I personally think it's a backlight issue (faulty LEDs). Could you help me confirm my diagnosis?
        I've checked and the T-CON seems to be fine. I disconnected one ribbon cable at a time at the bottom, but the problem persists.
        The Ambilight works perfectly and stays on.
        No sounds.
        Thanks in advance.
        08-25-2024, 04:33 AM
      • Comp_Pro
        No Backlight Macbook A1990 820-01041
        by Comp_Pro
        Hello all,
        Am trying to figure out this backlight issue with this A1990 Macbook Pro.
        Tests performed:
        There is no backlight even with a good screen.
        Backlight IC is receiving the correct support voltages.
        Fuse F8400 ok
        Current sense resistor R8400 ok
        Backlight IC is receiving 3.3V on enable pin.
        Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
        Backlight IC receiving 5V from PP5V_G3S
        Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
        I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
        05-06-2024, 10:23 PM
      • pajdek
        Lenovo Y700-17ISK turn on and off
        by pajdek
        Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
        09-20-2023, 02:49 AM
      • cheebster
        iPad Pro 12.9 5th Gen Backlight Issue
        by cheebster
        Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
        Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
        Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
        The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
        Anyone...
        05-20-2025, 09:17 AM
