hyundai hpt-4260 blue screen, main board or control
  • noledud
    • Dec 2013
    • 413
    • united kingdom
    hi all
    got this one going after a PS problem
    all looked ok but the screen just turned blue after a couple of flickers
    iv reseated everything and cleaned connections
    when the set is blue no amount of poking cables and twisting things changes the colour
    now the strange bit is if i left it off for a few minutes then the picture is normal for a few seconds befor it flickers and goes back to blue
    if you call up the menu that looks normal so im thinking its an issue with the main but can someone confirm ?
  • noledud
    • Dec 2013
    • 413
    • united kingdom
    Re: hyundai hpt-4260 blue screen, main board or control
    it happens on PC input also oh and the analog turner looks normal as well
      Well, you have your answer, the only board that discriminates analog tuner and normal inputs is the main board.
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • gbbradshaw
        Samsung 65" UE65TU7000KXXU VER:02/UTU7000 TV Blue screen
        by gbbradshaw
        Hi.
        I have the Samsung TV Model: UE65TU7000KXXU VER:02/UTU7000 which has developed the following issue: blue screen while the sound it's still working. This happened after the screen developed some horizontal lines at first and then the next day suddenly turned into blue background. the screen was not damaged or anything. I can't access the menu. I have taken the tv to a local tech to have a look and he said that he thinks that it might be the pcb board as the back-lights are working and the sound aswell . I was hoping maybe you can guide me if I should buy the pcb board or not? Thanks
        02-22-2023, 01:31 AM
      • Abdulrhman Alabsi
        Dell precision 7530 blue screen
        by Abdulrhman Alabsi
        I have problem in my laptop, When I try to enter to windows it showes me blue screen, I changed hard driver and ram but it did the samthing...please give me the solution of it
        02-09-2025, 10:39 AM
      • spice_disc
        Vizio TV M50-C1 reboot cycle and static on screen
        by spice_disc
        I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
        The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
        09-08-2024, 02:37 PM
