Parts list for Emerson LC320EM2
  • joeshannallie
    • Dec 2013
    • 103
    • usa
    Can someone make up a parts list for the repair kit with alternate part numbers that will work for the Emerson LC320EM2 power supply? I would like to see if I can get the parts at Radio Shack instead of Ebay.
  • joeshannallie
    • Dec 2013
    • 103
    • usa
    Re: Parts list for Emerson LC320EM2
    Bump
    • joeshannallie
      • Dec 2013
      • 103
      • usa
      Surely someone knows the part numbers or the alternate numbers on the parts that are in the repair kit.
      • dcapper
        • Dec 2013
        • 496
        RS won't have the mosfets you need. Shop Jimmy has a kit:
        http://www.shopjimmy.com/emerson-a17...repair-kit.htm
        You also can look for the parts on www.digikey.com
        • joeshannallie
          • Dec 2013
          • 103
          • usa
          That would be great if I knew the actual part numbers to look for and not just the number on the board where they are located.
            Here is the service manual, then look at shopjimmy part designators for what are being replaced in the diagram.
            Description Quantity Board Location
            Fuse 1 F601
            Resistors 3 R602, 608, 611
            Transistors 2 Q600 & Q601
            Diodes 4 D604, D607, D610, & D640
            • joeshannallie
              • Dec 2013
              • 103
              • usa
              Thanks OL' buddy, I was wondering where you was at.
              Fuse 1 F601
                I hate this badly designed circuit which is used in FUNAI, SYLVANIA, EMERSON,and PHILIPS.
                You mat want to read these also:
                https://www.badcaps.net/forum/showth...EM2#post405365
                https://www.badcaps.net/forum/search...archid=4031734
                • joeshannallie
                  • Dec 2013
                  • 103
                  • usa
                  I am sorry Bud but can you explain to me what shopjimmy designators mean? I apologize for being so dumb on this stuff.
                  • joeshannallie
                    • Dec 2013
                    • 103
                    • usa
                    Will NTE5806 Recifier 600v PRV 3A Axial Lead replace IN5406?
                    • Caleb
                      Smokin IC's
                      • Feb 2013
                      • 645
                      Q600- TK10A50D mosfet digikey part number TK10A60DSTA4QM-ND
                      Q601- 2sc2120y transistor can sub bc337 if you wrap emitter BC33740TACT-ND
                      D604- 27v 500ma zener digikey part number 1N5254BFSCT-ND
                      D610- 36v 1w zener digikey part number 1N4753A-TPCT-ND
                      D609- 1n4148 digikey part number 1N4148TACT-ND
                      D640- rectifier digikey part number S320FSCT-ND
                      R602- 2.2 ohm 5w digikey part number 2.2W-5-ND
                      R611- 2.2 ohm 5w digikey part number 2.2W-5-ND
                      R608- .18 ohm 2w digikey part number 0.18AETR-ND
                      Fuse 4 amp slow digikey part number 507-1252-ND
                      BTW those are upgraded parts on the mosfet and rectifier diode so hopefully it wont fail again so soon
                      Liberating magic smoke one part at a time
                      • joeshannallie
                        • Dec 2013
                        • 103
                        • usa
                        Thanks Caleb, What do you mean when you if you wrap emitter?
                        • Caleb
                          Smokin IC's
                          • Feb 2013
                          • 645
                          Pin out is not the same on the bc337 so you have to insulate the emitter leg and wrap it to the opposite side of the transistor to get the correct pin out. Its much easier to use the exact transistor replacement, but if you need to sub with parts all from one source, digikey has everything listed.
                          • joeshannallie
                            • Dec 2013
                            • 103
                            • usa
                            What is D609 "4148"
                              1n4148
                              • joeshannallie
                                • Dec 2013
                                • 103
                                • usa
                                Thanks guys. Much appreciated.
                                • Caleb
                                  Smokin IC's
                                  • Feb 2013
                                  • 645
                                  Sorry about that, It is such a common part I just assumed everyone knows. I put all the digikey numbers into post above to alleviate any more confusion.
                                  • joeshannallie
                                    • Dec 2013
                                    • 103
                                    • usa
                                    Is there a alternate part number that will be just the same or that will work on the 0.18AETR-ND? Can not find it anywhere.
                                    • Caleb
                                      Smokin IC's
                                      • Feb 2013
                                      • 645
                                      I've subbed in a .2 ohm 2 watt before when I couldn't get .18 ohm resistors. I'm pretty sure digikey had them in stock when I looked the other day. Here's the link
                                      Its 5 watt but you should be able to shoe horn it in, or you can try to sub out with .2 ohm can be found here
                                      • bufferb
                                        • Jan 2016
                                        • 10
                                        • canada
                                        LC320EM2 I SEE THIS BUT WHAT IS ZENER DIODE #648 ------------------------------------Q600- TK10A50D mosfet digikey part number TK10A60DSTA4QM-ND
                                        • Mark D
                                          Samsung UN65JU67ODFXZA Version TD01 Schematic and Parts List
                                          by Mark D
                                          The TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
                                          10-29-2024, 03:15 PM
                                          Samsung UN82NU8000FXZA LCD TV Parts List
                                          Samsung UN82NU8000FXZA 82" LCD TV Parts List...
                                          11-01-2024, 06:16 AM
                                          Chuwi Larkbox X, Parts list BOM
                                          by SMDFlea
                                          Chuwi Larkbox X, Parts list BOM...
                                          12-02-2022, 05:12 PM
                                        • zen
                                          WH1000XM4, Sony headphones exploded view & parts list please
                                          by zen
                                          These headphones sell for between £250 - £300 so well worth going into.
                                          Need to identify earpiece swivel brackets LEFT/RIGHT.
                                          Right side damaged.
                                          Manage to modify original & now works quite well, but it does seem to be a weak point on these headsets therefore would like to have some in stock for future repairs.
                                          Firstly, would like to find out if Sony supply these as separate parts & if not then try to have them 3D printed.
                                          Can anyone help?
                                          11-05-2022, 02:15 AM
                                        • DrDos
                                          Kenwood KR-6030 vintage stereo ,Old Man Trying to Save a Buck
                                          by DrDos
                                          Hello all. I'll try to keep this short. I have no knowledge of electronics. I can use a multimeter and am familiar with caps to some extent. I bought a Kenwood KR-6030 vintage stereo. It need work and so I thought I would recap the thing since I get power to the on switch but nothing else is working. No lights, no sound and so forth. I went to Mouser to order caps and I find I am way over my head. I not only do not know the type of capacitors I need but Mouser and digikey do not accept Kenwood part numbers. I have the info such as 220uF 63v and such but no place to put it. I could buy a recap...
                                          Today, 03:16 AM
