Vizio Vo47L FHDTV30A dead randomly
  • ej207
    • Oct 2014
    • 9
    hello im trying to trouble shoot a Vizio Model# VO47L FHDTV30A
    I tested all the pins in the plugs to the bottom right of the board and no voltage?. Weird i thought, so I made sure my multimeter was O.K. by testing other devices, even the wall outlet haha. No voltage at any pins.
    Quick history on the board, previous owner which is an old friend of mine replaced two resistors not sure when or if they were even right can't find schematics on psu for this model googled for a while.
    R901
    R601
    I'm not sure when was repaired to the time it broke on me, probably a few months? I was watching the TV and it shut off. No power led's nothing its completely dead. I have fixed some TV's in the past that just had the obvious blown caps, I don't see any bulging caps. Here is some pics of the boards i'm looking for some advice on troubleshooting to find the bad component to try fixing it and if worse comes to worse i'll just replace it but I would love to avoid ebay if anyone has some site recommendations.
  • ej207
    • Oct 2014
    • 9
    Re: Vizio Vo47L FHDTV30A dead randomly
    pic post
    • triplefour
      • May 2014
      • 1747
      checked fuse? volts at main filter cap? (careful thats the deadly one)
      Don't fear the repair...
      • ej207
        • Oct 2014
        • 9
        I've checked all fuses and i'll try that, what voltages am I looking for?
        • triplefour
          • May 2014
          • 1747
          on the main filter cap you should see 160-170v
          keep the black probe on the negative leg of the main filter cap, and probe the diodes in the area next to it to see where you lose voltage?
          i havent had a lot of success yet with repairing PSU's at component level. i still need a lot of help from the masters here
          but just be cafeful with that main filter cap thats all i can say cuz it hurts!
          • ej207
            • Oct 2014
            • 9
            Nice, I will try that. I don't know what the main filter cap is though.. i will google some pics and see if i can't figure that out thanks
            • triplefour
              • May 2014
              • 1747
              its the biggest capacitor on the board. in your case, the one that is surrounded by the heat sink but not under it
              • ej207
                • Oct 2014
                • 9
                in CAP mode on multimeter, readings were erratic but only when recontacting multimeter probes. im no pro, not sure if that is even an appropriate setting.
                as this picture illustrates, that huge cap was reading 160 volts. im not sure how to test those resistors maybe my multimeter sucks but on both leads it was still 160 volts
                • triplefour
                  • May 2014
                  • 1747
                  not sure about the CAP setting on your multimeter. mine doesnt have one. just setting your meter to 200v DC range should be good enough.
                  • ej207
                    • Oct 2014
                    • 9
                    Yep, that was my result. Appreciate you taking the time to help e-troubleshoot.
                    idk what voltage should be at the cap, i don't have any schematics for this PSU. do you? I have googled !
                      Voltage on the main cap should be 160~170VDC in standby mode, > 350VDC when TV is on.
                      I need good clear pictures of the bottom side of this power supply-inverter board combo, the whole board picture and in closed up in quarter section so I can easily trace the connections on the bottom side of the board.
                      BTW, you do not have any DC Voltage at the 5VSB pins at all?
                      • tvguy12012012120
                        by tvguy12012012120
                        02-07-2025, 05:13 PM
                      • Iain P
                        Vizio E65-F0 really dead
                        by Iain P
                        Hi everybody!
                        I've got a Vizio E65-F0 smart tv that is good and dead. It shows no signs of life when I press the power button on the back. The power LED in the lower right corner doesn't light, there is no backlight and no picture.
                        So I took the back off and started poking around figuring one or more of the caps had dried out. My esr meter says all the caps on the power supply board and the mainboard are less than 1 ohm.
                        I decided to check the voltages coming off the power supply they are as follows:
                        connector CN201
                        pin 1 (18vsb1)...
                        02-23-2023, 11:32 AM
                      • catnapped
                        Dead Vizio D40u-D1
                        by catnapped
                        Recently had my bedroom Vizio D40u-D1 apparently die while it wasn't being used. Noticed the power LED flashing, figuring maybe a software upgrade, but attempting to turn it on proved that wasn't the case. When powered on, the power LED will flash a bunch of times after about 2 minutes then turn off again. Definitely is no picture even with a flashlight on the screen. Had the opportunity to open it up over the weekend. Doesn't apper to be anything out of the ordinary visibly inside, nor any odd smells of escaped magic smoke. Readings from the connector in the corner of the power supply board...
                        04-02-2024, 08:55 AM
                      • fharris1977
                        Vizio D50u-D1 Dead: PSU or Main Board?
                        by fharris1977
                        Hi. Anyone who has experience with these vizio sets, which pin on this connector is the standby, the 5V pin? Trying to rule out the PSU before ordering a mainboard. I'm getting 0 Volts on all pins on this connector. Trying to jump the standby and PS ON pins to see if the PSU is functioning. Thanks in advance.
                        03-12-2024, 12:22 PM
