Wide Black Vertical Line Samsung Plasma NOT Panel
  • mmartell
    • Oct 2013
    • 3189
    Re: Wide Black Vertical Line Samsung Plasma NOT Panel
    Originally posted by tw2005
    whatever you do, don't run the tv without the metal strip heatsink across those ribbons.
    Haha I remember you saying that in another thread and that very thought popped into my head when I briefly considered doing just that ! So thanks
    • tw2005
      • Oct 2011
      • 6458
      Yeah, I only just remembered as i thought the temptation of you doing so would be great. What's funnier is i thought it was for bracing, the chips fried before I knew what was going on ,
      • tw2005
        • Oct 2011
        • 6458
        Sorry I should have clarified... that is a Shopjimmy pic of the buffer I thought I had until I disassembled my tv to find NO connectors. That board was just for illustration as I think everything else is the same.
        I'd like to see a photo.
        • mmartell
          • Oct 2013
          • 3189
          Sorry man, all back together. It looks exactly like how panel ribbons affix to the boards in between the tcon and panel in an lcd.
            09-07-2024, 05:50 AM
          • mrsith
            Samsung UE58TU7100K - no picture, vertical line
            by mrsith
            Hi.
            Got UE58TU7100K with no picture - backlight comes on though. Figured out that's a perfect candidate for cut tape method.
            This model has just one LVDS tape coming off main board - and two panel boards underneath the LCD screen are connected to each other via small tape. Like curved screens. I've tried to disconnect half of the screen (5he side without LVDS connector on it, obviously), no joy.
            Disconnected the tape (main board side). Applied a small piece of tape, covering first ~4-5 pins. Powered the TV on - got picture. In negative, but that's...
            02-07-2023, 11:18 AM
          • kotel studios
            Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
            by kotel studios
            Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
            In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
            08-06-2025, 02:07 AM
          • otaku_nut
            Vizio E701i-A3 fixed but now has red vertical line
            by otaku_nut
            Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
            08-19-2025, 06:11 PM
          • thetonywarren
            Samsung PN51E450 Plasma Vertical Lines
            by thetonywarren
            Friend of mine has a Samsung Plasma panel with some vertical lines that are starting to form on the screen.....Ive never worked on a plasma panel, so Im not sure what to look for, would this typically be a main board issue, or something else?
            Any help would be appreciated.....Please let me know.......
            02-14-2022, 01:23 PM
