Wide Black Vertical Line Samsung Plasma NOT Panel
  • mmartell
    • Oct 2013
    • 3189
    Before I repaired the ymain and buffers on this set (hp-t5054) I broke two caps off the e-buffer when removing the mainboard assembly to get to the control board. I just replaced the two caps and the problem remains.
    The line is where I would guess the addressing begins (on the left) but the broken caps were on the center right of the address board when looking at the screen. In other words not in the direct vicinity of the fault.
    Is the affected E-Buffer to blame for this or can the Control Board cause this as that was replaced as well ?
    (Hard to see the affected area because it blends with the black frame but the light is shining on it in the second pic)
    Re: Wide Black Vertical Line Samsung Plasma NOT Panel
    If you broke the caps could you have damaged the PCB?
    Can still be panel .... unlikely though as you mention, would be a bad coincidence. Did you have it working before?
    • tw2005
      • Oct 2011
      • 6458
      Be careful with the power lead to those bottom buffers. this is the panel i killed reconnecting that , large arc and destroyed the TV due to residual voltage.
      Pictures of the board? There are buffer ICs on tha board. i have the F buffer in front of me and they're mounted midway. maybe one of those is damaged. The drive signal pass through those.
      HB541(SN74AHCT541) very common, find on main boards, buffer boards, y and maybe x if you wanted to experiment changing one. Not a bad size to work with
      • tw2005
        • Oct 2011
        • 6458
        Isn't it the F buffer that drives the left side you say has the black lines?
        • mmartell
          • Oct 2013
          • 3189
          I want to say it wasn't always like that but can't be sure. Though with the Y buffers in and out of the set I think I would have noticed the bar if it were there.
          Can a control board fail in this fashion ? When I get some time I will have a closer look at the E Buffer.
          • mmartell
            • Oct 2013
            • 3189
            Exactly my point. I thought each of the address buffers was responsible for a half of the screen and the faults are opposite !
            • tw2005
              • Oct 2011
              • 6458
              I don't understand
              The black bar is on the left?(I can't make it)
              The F buffer drives the left?
              I don't think the E or those caps would have anything to do with it.
              If the buffer was spiked , could produce a black bar, that is what happened to me but mine was not at the very edge.
              I guess missing signals anywhere along the path could do it. Never traced these I guess an oscilloscope would be needed.
              I'll take the back seat on this one
              • mmartell
                • Oct 2013
                • 3189
                Right. My assumption is that the address buffers work similar to the Y buffers in that a fault would be localized to the area served by the buffer which is not the case here. Perhaps the address buffers don't work that way.
                I don't remember disconnecting the connector to the F buffer as I had no reason to do so.
                  It is possible for the control board to cause this fault on some earlier panels. Not sure about this one. On newer panels it's very unlikely. Picture of the control board?
                  • mmartell
                    • Oct 2013
                    • 3189
                    Right here, tom.
                    http://www.shopjimmy.com/media/catal...bn9606522a.jpg
                      That's a newer generation (no logic buffer ICs) so I'd say that wouldn't cause the fault.
                      • mmartell
                        • Oct 2013
                        • 3189
                        Ok so E or F buffer. Is each buffer responsible for one half of the screen or do they not work like that ?
                          Yes they are responsible for each half but they really are only data buffers. They do not process the video in any way. Just provide power (Va ~60VDC, Vcc ~5VDC/~3.3VDC), clock, data and reset signals..
                          • mmartell
                            • Oct 2013
                            • 3189
                            But I clobbered the caps on the E buffer and the picture fault is on the opposite side so to boil it down I have a problem with my F Buffer or I may in fact have a bad panel.
                              I think F-buffer or panel at fault here. Probably unrelated damage.
                              • mmartell
                                • Oct 2013
                                • 3189
                                I went to remove the F-Buffer but found the panel ribbons bonded to the buffers instead of terminating into connectors. Buggers!
                                I called the thread "...NOT Panel" that may have been premature. How can I probe or scope that ribbon on the address board to see if the signals are indeed there ?
                                  Huh? Those look like they terminate into connectors...? What am I missing?
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    No , that's not right, std lever action connector and ribbon
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      whatever you do, don't run the tv without the metal strip heatsink across those ribbons.
                                      • mmartell
                                        • Oct 2013
                                        • 3189
                                        Sorry I should have clarified... that is a Shopjimmy pic of the buffer I thought I had until I disassembled my tv to find NO connectors. That board was just for illustration as I think everything else is the same.
                                        • mrsith
                                          Samsung UE58TU7100K - no picture, vertical line
                                          by mrsith
                                          Hi.
                                          Got UE58TU7100K with no picture - backlight comes on though. Figured out that's a perfect candidate for cut tape method.
                                          This model has just one LVDS tape coming off main board - and two panel boards underneath the LCD screen are connected to each other via small tape. Like curved screens. I've tried to disconnect half of the screen (5he side without LVDS connector on it, obviously), no joy.
                                          Disconnected the tape (main board side). Applied a small piece of tape, covering first ~4-5 pins. Powered the TV on - got picture. In negative, but that's...
                                          02-07-2023, 11:18 AM
                                          09-07-2024, 05:50 AM
                                        • thetonywarren
                                          Samsung PN51E450 Plasma Vertical Lines
                                          by thetonywarren
                                          Friend of mine has a Samsung Plasma panel with some vertical lines that are starting to form on the screen.....Ive never worked on a plasma panel, so Im not sure what to look for, would this typically be a main board issue, or something else?
                                          Any help would be appreciated.....Please let me know.......
                                          02-14-2022, 01:23 PM
                                        • afex
                                          Samsung Plasma TV with vertical lines (model PN50B430P2D)
                                          by afex
                                          This is my 2nd broken TV I'm trying to fix and haven't been able to figure out... currently going without any working TVs so am hoping to be able to fix one..
                                          This Samsung PN50B430P2D Plasma has this big block of vertical lines which will fade in shortly after turning the TV on. The lines will sometimes flicker a bit or fade in/out and sometimes it just stays present. The length of time it takes them to appear varies, sometimes its a few minutes and other times it appears immediately after powering on.
                                          I have attached an image of the TV with these bars displaying....
                                          11-08-2021, 09:23 PM
                                        • sputnikoff
                                          samsung un58tu7050 single vertical line.
                                          by sputnikoff
                                          Had a friend drop this tv off and initial issue was no power.I could see faint glow when powered up .Lamps all fired up fine.I removed flat lvds cable and reseated it,then tv screen came on.After i reassembled it now has single line pretty well dead center of screen.Is there ongoing display issues anyone is aware of.Any input welcome.
                                          02-25-2023, 09:42 AM
