LG 32", 32PG6000 Plasma keeps blowing IGBT's intermittently
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    I have this rather smart 32" Plasma set. It was dead, cycling from standby/on then standby every second or so.
    Checks revealed short IGBT's on the Combined X/Y SUS board. (That tiny 'X-SUS' isnt really anything more than two diodes and a couple of caps)
    Its the X-SUS part of the circuit thats failing. Q603 and Q604 'Sus-Up' and Q18, Z-Ramp that go short-circuit. These are GT30F122, a 30A 300V IGBT by Toshiba.
    I replaced these with the GT45F122, a 45A 300V IGBT by Toshiba. Both these parts are designed for PDP service, and not had issues subbing these in the past for the 30A version....
    First time round, after replacement, the set ran for 15 minutes, then all three short again.
    After that, I de-cased the panel and checked very closely for any abnormalities of the display surface, Spots or burns, and the Mylar connections/tabs to the panel. All appears fine.
    After much testing and a few caps replaced/dry-joints resoldered etc and the three replaced again, along with a 2.2 ohm resistor this time that had also failed, (R22, supply from Vs to the 'VSC' inverter amongst other things) the set ran fine for firstly 1 hour, then next day for three hours, then turned off off for 10 minutes and then on again for another 3 or 4 hours.
    This morning, set ran for an hour or so, then again a small 'Tick' and no picture followed by the PSU relay and back to standby.
    Checks again show the same three IGBT's short-circuit. When working, the set gave a good picture although the black-level was a little high for a plasma, but not really objectionable.
    The three IGBT's are connected, first two in parallel fed from Vs, the sources of these to the drain of the Z-Ramp one, and the joint between 'em to the ERC coil, and by the multi-way thick leads over to the Z-SUS diode-board attached to the Z-tabs.....
    I'm thinking somehow the timing/drive to these is failing/corrupted for an instant leading to shoot-through and shorting....
    Any ideas what would be causing this...?
    TELEFIX
    Re: LG 32", 32PG6000 Plasma keeps blowing IGBT's intermittently
    When you replaced the IGBTs, did you also replace the driver ICs for them?
    What voltage is Vzbias set to? Is it matching the panel setting?
    If Vsc resistor is bad, are you sure the Z-side only is affected? (Vsc is only for Y-side)
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      I didn't replace the three-legged driver devices. Difficult to tell what they are, I Think Transistors due to the test-readings
      VZBias isn't settable. There's only two presets on the board, Set_Up and SET_Dn, VZBias was correct, as was all voltages.
      I think the resistor failed when the Vs collapsed suddenly due to the short, and the de-coupling-cap the other side of it fed it with sufficient energy to kill it. It wasn't burned or even marked, just O/C.
      This time round, its still OK
      TELEFIX
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        So,--Ive now replaced the two driver-transistors that drive the pair of SUS_Up IGBTS.
        --These are an NPN and a PNP with both emitters and base connected together.
        Ive also replaced the Tiny transistor that drives the Z-Ramp IGBT. and checked all the small diodes etc in the network around it.
        Any more suspects....?
        TELEFIX
          The IC which drives those NPN/PNP transistors can also be suspect.
          • Alastair E
            Chief Womble
            • Mar 2013
            • 1963
            • U.K.
            Ah--OK, I can replace that one no probs, IRS2106, High/Low side Gate driver chip.
            But--There's another, weird thing, (That drives the Ramp IGBT via this network and transistor)
            --Seen them in practically every plasma set, its a SOIC 08 package--But is three times the height from the board to top, a fat little bugger marked, 35H817.
            --theres various versions it seems, like 34H807 (which is the closest I can find on a board,) and nothing on the web about 'em....
            I always assumed they were 'dual opto-couplers'--if such a thing exists....
            I might as well replace this thing as well, before killing another £12 of IGBTs......
            Any ideas what these things are?
            TELEFIX
              It will be some kind of optoisolator. It is odd for a Z-ramp FET to be driven with an opto though. It will be driven normally via a simple gate driver with a gate-drain capacitor to limit the slew rate.
              • Biruslapio
                Samsung PL42C450 plasma X-Main IGBTs
                by Biruslapio
                Hello, the problem with this TV is it has all the Y and X voltages, but does not produce any image.
                It had a TON of cracked solder joints on these boards, fixed all that I could find, but in the last test I forgot to plug in the Y-SUS to control board flat cable, it was left dangling and possibly some pins shorted to the panel metal ground, the X-Main buzzed quietly then blew up in 3 seconds after powering up, annoying.
                Two RJH30E2 shorted, they are 360V 35A 1.7VCE IGBTs, the problem is I don't have any 360V IGBTs, only 300V or 600V, would two RJP3065 fit in? It's...
                04-08-2022, 01:16 PM
              • Keshenatech1
                LG 50PJ350 plasma blowing Y-Sustain board
                by Keshenatech1
                Hi, I was wondering if there's anyone here with experience on the LG50PJ350 plasma or similar models? When it came in, it had 7 shorted mosfet outputs on the Y-sustain board, Q02, 04,11, 22, 24, 26, and 28 were all dead shorted. I replaced them with the exact same type, checked their surrounding area for other open and shorted components and didn't see any further problems. But as soon as I hit the power button on the remote, I had a loud Pop! and Q22, 24, 26, and 28 are shorted out again. The other 3 seem to have survived. Someone on another forum had suggested the possibility of a shorted panel....
                05-13-2020, 10:08 AM
                Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                12-14-2023, 07:45 PM
              • grimacelord
                Xbox One S - 12V Rail Short - Q9F1 Keeps Blowing
                by grimacelord
                Have an Xbox One S here that has a short on the 12V power rail. There is no power, beep, or partial fan spin when connecting power cable.
                After diagnosing with thermal camera, Q9F1 MOSFET (NTTFS4C50N) is getting hot. When I remove this MOSFET, the short on the 12V rail disappears.
                I first replaced Q9F1 with one from a donor board and then partially reassembled the Xbox to test. When I plugged the power cord in, I got a partial fan spin and I thought I had fixed it, but unfortunately, the Xbox still did not power on. So I then disassembled the Xbox...
                10-24-2024, 12:31 PM
              • 90Ninety
                Dell XPS 8100 Motherboard VRMS keep blowing
                by 90Ninety
                I wanted to save this thing from E-waste ... I helped a neighbour with their Dell PC , it had a blown visably blown VRM causing a short on the 12V EPS ..
                I replaced this VRM which fixed the short but, the high side VRM's keep blowing , seemingly the same two phases .. I replaced the low side mosfets on the respective blown phases . Though still the High side VRMS are blowing ..
                After a few minutes one of the four phases will get extremely hot , then blow ..
                I purchased replacement VRMS both High Side (72T02GH) and Low side (86T02GH). Pictured below , I just...
                10-05-2024, 08:36 AM
