LG 50PS3000 clicks
  • vili23
    • Sep 2014
    • 24
    • Croatia
    LG 50PS3000 clicks
    hi!
    I'm having problems with my LG plazma 50PS300.
    I'm suspecting the power supply board EAY60716801.
    When I power it on it makes 2 clicks and goes to stand by.
    When I turn it on (button or remote) the LED blinks 6 times blue and then turns red.
    The coil marked on the picture starts to buzz.
    I mesured the voltages and they are all 0 except stby5v which is 5V.
    Tried with all board connected to PS and all boards disconnected, its the same.
    I also tested all fuses and they are ok.Tested all diodes and i think they are ok (not open or shorted). Also I tried to change the voltage regulator IC301 (STRW6252S) and the red capasitor marked on the picture.
    Nothing changed. Please advise me what to do next.
    If you need more info please tell and I will provide.
    Sorry for my English, not my native language.
    thanx
    Re: LG 50PS3000 clicks
    With Y-sus and Z-sus boards unplugged (all others connected) and power board installed, what voltages do you measure on Vs and Va?
    • vili23
      • Sep 2014
      • 24
      • Croatia
      The voltages are all zero
      • vili23
        • Sep 2014
        • 24
        • Croatia
        Gentle nudge.
        • topng
          • Dec 2013
          • 56
          • ISRAEL
          It's almost the same fault all the lg check the power resistor, in the main power board.
          and transistor ,30v zener diode.
          • vili23
            • Sep 2014
            • 24
            • Croatia
            Can you tell me please where are this elements you are talking about?
            • vili23
              • Sep 2014
              • 24
              • Croatia
              Do you mean the components in this kit?
              http://www.ohmsupplies.co.uk/REPAIR-...Y-IC301-FAULTY
              I tested them all and changed Ic301 and they are all ok.
              This board is driving me crazy
                Did you check VS ON, M5V ON and RL ON signals on main board connector (it goes to power board)?
                • vili23
                  • Sep 2014
                  • 24
                  • Croatia
                  I did,they are all 0V except
                  AC_DET 5V
                  AUTO_GND 4.1V
                  KEY_ON 4,5V
                  STBY5V 5V
                    OK, can you get hold of some 100~470 ohm through hole resistors?
                    • vili23
                      • Sep 2014
                      • 24
                      • Croatia
                      i got them, what's next?
                      • vili23
                        • Sep 2014
                        • 24
                        • Croatia
                        Hey Tom66
                        Could you tell me what to jump with this resistors and what scould happen
                          Sorry, missed your post.
                          Please locate a 5V supply (STBY5V pin will do fine) and connect one resistor to VS ON, RL ON and M5V ON. Unplug the connector from the main board end (the connector with the VS ON etc on it)
                          Then, plug the TV in. Do you see a faint glow from the display panel? Do you measure good Vs and Va on power board?
                          If so, step 2:
                          Unplug power to the TV.
                          On the control board, which is the board below the power board and connects to most of the other boards: jumper the EXT AUTO GEN pins marked 1 and 2 (a small wire works well)
                          Unplug the LVDS cable which runs between the main A/V board (HDMI inputs etc) and the control board.
                          Plug the TV back in. Do you get cycling test patterns?
                          • vili23
                            • Sep 2014
                            • 24
                            • Croatia
                            Hey
                            I did what you told me but nothing,no glow and no voltages.
                            What do you think, could it be just the ps board because i'm thinking about purchasing a new one.
                              When you do those steps, did you hear a click or two from the power board? Do you measure 17V on the main board connector (unplugged)?
                              • vili23
                                • Sep 2014
                                • 24
                                • Croatia
                                When i connect the power cable the board clicks two times fast, click-clack
                                Like it powers on and off right away.
                                There is no voltage at 17V pin.
                                  OK, now try with the Y-sustain and Z-sustain unplugged.
                                  Y-sustain is large green board on left hand side of TV.
                                  Z-sustain is large green or beige or orange board on right hand side of TV.
                                  (Both looking from the back.)
                                  • vili23
                                    • Sep 2014
                                    • 24
                                    • Croatia
                                    tried with the two boards connected and disconnected and it's the same
                                    just click-clack and no voltages
                                      Ok, this points to a power board fault.
                                      On the power board, are all fuses good? Use continuity range to test them.
                                      • vili23
                                        • Sep 2014
                                        • 24
                                        • Croatia
                                        i ordered a new board,found it on ebay for 26 quid with shipping, i will try with that and see.thanx for the help so far
                                        • Maniackk
                                          Reader PocketBook InkPad 3 – identification of a black component marked 'CT' on the microUSB line
                                          by Maniackk
                                          Device: PocketBook InkPad 3
                                          Mainboard: XRZ_E091_PB740-VTTOA-V1.1 / 2017-10-12
                                          I'm replacing the broken microUSB connector on this e-reader, and during inspection after desoldering, I noticed a loose black SMD component marked "CT". One of them was torn off along with the pad, while the other one (marked in the photo) is still in place.
                                          I would appreciate help identifying this component.
                                          Measuring the loose component with a multimeter gives 5.84 MΩ in both directions, while the one still on the board shows no measurable...
                                          05-16-2025, 08:53 AM
                                        • GRANDGG
                                          LG 42lw4500 flashing red light , wight light , 2 clicks
                                          by GRANDGG
                                          Hi i have an issue with LG 42lw4500 wich after pressing the power button flashes red then goes solid white light 2 clicks and nothing , the weird thing is SOMETIMES if i leave the tv plugged in it would come on and fuction normally (i should mention that vertical rectangle going from the bottom to the top of the screen have some red dot artafacts it only appear in somthing like the tv input menu and any input i give like vga , but not in the system menu , i thought i should mention this , i cannot confirme if the tv had this issue when it was up and running in its previous owner . ) when checking...
                                          05-09-2025, 12:27 PM
                                        • Geosphere
                                          Help identifying SOT-23-5 regulator marked BFCV on Lucky Miner LV06
                                          by Geosphere
                                          I’m trying to repair a Lucky Miner LV06 Bitcoin miner that was given to me.
                                          It looks like someone plugged 12 V into the 5 V rail and fried the three small adjustable regulators.
                                          Each regulator is a SOT-23-5 package, all marked “BFCV.” I can’t find any datasheet or reference to that code. The regulators appear to generate 3.3 V (for ESP32), 1.8 V, and ~0.8 V (for the BM1366 ASICs), set by resistor dividers?.
                                          From tracing the PCB:
                                          Pin 1 (red) → 5 V in
                                          Pin 2 > GND
                                          Pin 3 (yellow) > output ...
                                          09-19-2025, 12:24 PM
                                        • CoinCoin88
                                          Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                          by CoinCoin88
                                          I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                          Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                          09-15-2025, 03:36 AM
                                        • Francesc V.
                                          Diode marked as "E57".........not able to find it by reference
                                          by Francesc V.
                                          Hi:
                                          I have what it might seem a zener diode. It's marked as E57, but I haven't found any reference that might match my observations.
                                          I've took one from the same circuit and tested isolated with the power supply and a 1k resistor. with 10V, the possible zener stays at 6.6V.
                                          It seems a SOD123 package. It measures (2.6mm x 1.6 mm).
                                          Any idea? it's a 6.6V zener?
                                          06-14-2025, 09:56 AM
