Samsung LN52A650A1F no backlight
  • NUTIN2LUZ
    • 61
    Here's another TV that I need help on. A friend of mine gave me this TV because the backlights went out, but there is still sound. I turned it on and there was no backlight. On a different day it worked perfect. Prior to giving me the TV, my friend replaced 2 transistors Q1815 and Q1816 and all the caps. But the problem still happens. You can see the image with a flashlight on the screen. I was thinking of replacing the caps again just to make sure. Also thinking it might be the ccfl. Any thoughts?
  • kasfamily
    • Aug 2014
    • 765
    • Russia
    Re: Samsung LN52A650A1F no backlight
    Please photo solder side.Is not CCFL- backlight LED.
    • Shinju
      • Mar 2014
      • 1239
      No, this is CCLF UN are the LED panels.
      I have had a few of these, check the 24v on the Power supply for the Inverter side. these power supplies have the inverters built in.
      Sounds like you have a toasted inverter transformer or possible shorted FET. Also disconnect the main from the PS and plug the unit in and see if you get backlights.
      • kasfamily
        • Aug 2014
        • 765
        • Russia
        Sorry about the mistakes, believed the description of this model on the Internet.
        • NUTIN2LUZ
          • 61
          First picture are CM851, CM852, CM854, CM855. Second picture are CM856, CM858, CM859. Third and fourth pictures are the transistors Q815 and Q816.
            The inverter does not runs off 24V, it runs on Boosted Voltage from PFC Voltage booster around 390VDC, so verify first that the PFC Voltage is working or not but measuring the DC Voltage right at the two legs of the main filter caps. Check the solder joints on the board real well also.
            Also verify that you do have BL_ON signal and Dim signal from the main board.
            • Shinju
              • Mar 2014
              • 1239
              You are correct, my mistake. I haven't torn into one of these in awhile I just went though a few stand alone inverter panels and got narrow minded!
              Budm knows his stuff!
              • NUTIN2LUZ
                • 61
                I removed CNI803 and CN801 both from power supply to main board and no backlights turn on. Plugged in CNI803 with CN801 removed no backlights turn on automatic. Plugged in CN801 with CNI803 removed, no backlights turn on automatic.
                Where am I suppose to measure the 24v? Do I check them after the inverter as shown in picture?
                • NUTIN2LUZ
                  • 61
                  CP803 & CP804 main filter caps I have 335VDC.
                  BL_ON 4.88V
                  DIM 1.117V
                  Will check all the solder joints on the power supply when I get back home from work.
                  • Shinju
                    • Mar 2014
                    • 1239
                    Ignore the 24v I was mistaken! Follow budm's steps!
                      BL_ON 4.88V
                      DIM 1.117V
                      How about the PS_ON (POWER ON) when switch is activated?
                      The boosted voltage ON the cap is only showing 335VDC? It should be higher than that per diagram.
                      • NUTIN2LUZ
                        • 61
                        Sorry I've made a mistake at the filter caps. They are 390VDC when powered on and 162.4 when powered off.
                        PS_ON activated 4.3V
                        • NUTIN2LUZ
                          • 61
                          Backlight just went out. I can't seem to see any video in the background with a flashlight.
                          Voltages when backlights off sound good:
                          CN801
                          -PS_ON 4.28V (backlights off, sound good)
                          CNI803
                          -ON/OFF 4.86V (backlights on), 4.88V (backlight off, sound good)
                          -PWM 5.17V (backlights on), 1.119V (backlights off, sound good)
                            Please upload the pictures of whole backside of the TV. So the BL_ON is still present, that means the problem may be in the inverter section, the Balancer board, the lamps.
                            • NUTIN2LUZ
                              • 61
                              Picture of the BL_ON.
                              • NUTIN2LUZ
                                • 61
                                After my last post I've checked for cold solder joints and found some. After making those cold solder joints clean I've ran the TV for almost a month and have had no problems. Sold the TV and 12 days later the person that I sold the TV to told me that there is no picture, but the sound is there. He also told me that the screen is black with sound. What else could be the problem?
                                  09-07-2024, 05:50 AM
                                • sansanpartida
                                  Samsung QE82Q70RAT no backlight
                                  by sansanpartida
                                  Hi everyone!
                                  Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                                  My issue: No backlight.
                                  Model: QE82Q70RAT
                                  Type No: QE82Q70RAT
                                  The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                                  So hopefully, I can fix this cheaper.
                                  05-22-2024, 06:56 AM
                                • howardc64
                                  Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                                  by howardc64
                                  TV was fixed just after removing Samsung's rear snap cover.
                                  This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                                  Maybe PSU->backlight connector didn't have a good contact?...
                                  07-23-2025, 12:34 AM
                                • howardc64
                                  Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                  by howardc64
                                  • Prior owner tried a replacement main board. No difference.
                                  • Samsung 2x red blinking standby LED = panel fault
                                  • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                  • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                  • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                  07-19-2025, 10:54 PM
                                • Ierwin
                                  by Ierwin
                                  05-13-2025, 03:31 PM
