Sanyo plasma switching off!
  • nstlfrk
    • Apr 2014
    • 166
    Hello all I have a Sanyo Plasma that when you turn it on it starts to light up but then shuts off. I cant find any blown fuses or shorted parts and all the caps appear to be good. It just clicks when it turn on then of course clicks when it shuts down. Sometimes it will do this multiple times and other just once or twice. Can any of you give me an idea of just what it may be or where to start?
    Sanyo DP50749
    Here are some pics
    Re: Sanyo plasma switching off!
    When you say "light up", do you mean the screen glows briefly? (if only dimly)
    • nstlfrk
      • Apr 2014
      • 166
      exactly what I mean. Does not show any information as input or video just a light glow.
        OK, look at these two boards
        https://www.badcaps.net/forum/attach...6&d=1411130864
        https://www.badcaps.net/forum/attach...7&d=1411130864
        Is an LED glowing on them? If so does it stay lit? Do both glow?
        • nstlfrk
          • Apr 2014
          • 166
          There is a green led on the one on the left for sure. It just stays lit solid.
          I will have to check on the right one.
            On some Panasonic panel modules, there is no LED on the SS board (right hand board)
            Your TV has Sanyo main A/V board and software, but the display panel and driver electronics are manufactured by Panasonic (a good supplier.)
            • Glitcher
              • Mar 2013
              • 673
              • USa
              This is a very common problem with this model. It is a defective main board. There are repair kits on eBay for the main board but at times it's a hit and miss with it. Just wish someone would help figure out what was in those kits.
              • nstlfrk
                • Apr 2014
                • 166
                Do you still need me to check on the other board for the led?
                Also why does it matter if the LED is solid, on or off?
                • nstlfrk
                  • Apr 2014
                  • 166
                  The main board as in the one with all the inputs on it?
                  • nstlfrk
                    • Apr 2014
                    • 166
                    There is no led on the right board only the left and it stays on solid.
                    What do you think this means?
                      by sam_sam_sam
                      03-31-2024, 02:12 PM
                      by sam_sam_sam
                      07-01-2024, 06:34 AM
                    • Michale32086
                      FUNAI/SANYO FW55D25F Shuts Down Randomly
                      by Michale32086
                      I have Sanyo 55" TV that randomly shuts off..
                      Sometimes it will stay on for 5mins or so, sometimes it shuts off after a min or two...
                      When it DOES stay on, it works fine...
                      All things being equal, would it be more likely a POWER Board issue or a MAIN Board issue???
                      Thanx in advance......
                      07-12-2022, 12:41 PM
                    • berriferous
                      Samsung PN43E450A1FXZA (Plasma) - Display up for 4 mins, then shuts itself down
                      by berriferous
                      Set was manufactured in 2012. I'm trying to diagnose where the problem is. I am assuming it is over-currenting after heating up? Display looks fine until it decides to shutdown. If I keep turning it on, it will eventually refuse to power up and requires unplugging to get it to respond again.
                      I originally thought there would be some easily detected bad electrolytic capacitors, but I don't see the telltale signs. There might be some very minimal bulging on one of the x buffer board. BN96-22092A (LJ92-01852A).
                      If I unplug the power feed to the X/Y board (LJ92-01854B), the...
                      12-16-2024, 09:58 AM
                    • cloo
                      Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                      by cloo
                      I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                      It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                      So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                      After doing a factory reset this problem was gone and the picture was back to...
                      01-06-2025, 06:02 AM
