Insignia NS-55L260A13 LCD TV Won't stay on
  • Shane711
    • 493
    Re: Insignia NS-55L260A13 LCD TV Won't stay on
    I have found that these power boards have problems with loose solder joints. If your TV is dead or won't stay on check the solder joints on RT802 first and then inspect the entire board. If your TV still has problems staying on then Check the temperature of the RT802 when the TV turns off, if you find it to be hot then add a heat sink to it and place a small fan blowing at it, if your TV stays on after that then replace RT802 and keep the heat sink on it. You might also want to install a cooling fan so it never burns up again.
      Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
      by sam_sam_sam
      This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
      I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
      I am comparing them to a brand new one that I installed
      The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
      I going to let it run for several days before I remount back on the wall next to the...
      09-05-2024, 06:48 PM
    • koby058
      vostro comes up with back light but no picture
      by koby058
      Hi people!!
      The owner said it showed bad picture once in a while (attached)
      I see that there is back light but no picture.
      I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
      Also attached schematic and BDV
      LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590...
      07-13-2025, 01:03 PM
    • freakaftr8
      Asus a15 FA507RE-A15.R73050T failure
      by freakaftr8
      So this laptop seems to have some kind of failure. I bought it second hand and originally the previous owner said that they went to turn it on and it was presented with a quick flash of the power light the keyboard lit up and then the keyboard shut off and the power light went off as well but the battery indicator was white and after about 5 to 7 Seconds flashes orange really quick then shuts off and goes back to White. If the power button is pressed again the keyboard lights up really quick and then repeats. When I got it I could press the power button multiple times the keyboard light would...
      03-28-2024, 10:58 PM
    • jdawg99
      LG 47LA620V Same LED Failing Back Light Issues
      by jdawg99
      Hi All,
      I need some help with this one please. I am attempting a repair on the backlight. TV turns on and flashes the LG logo so stripped it down and found one faulty LED. Replaced it and tested on an LED tester and the strip was good. Put it back onto the PSU and it lasted about 20 seconds before going out again. Same LED had blown. Changed it for another type of SMD one (same voltage) and it seemed fine. Put the TV back together but it was quite dim. Noticed it was in power save mode so turned it off and the screen was bright. Left it on for half an hour only to come back to the...
      04-23-2023, 01:04 PM
    • boyebaran
      hisense 65k560 back light problem
      by boyebaran
      hi to all
      tv turn on and show logo(backlight on)than backlight turn off than red led in front blinking 7 time. the tv remote control working fine (sound on no picture).backlight changed same problem
      in 65k560 how to remove protection of backlight? picture of inverter and sockets attached .
      please advise me tnx
      05-20-2025, 07:11 AM
