TV Power Problem
  • tech2014
    • Aug 2014
    • 807
    TV Power Problem
    Hi guys. I have been posting a lot trying to get some help on an LG 60PC1D that has a power problem. I have decided to make a video and put it on youtube just to make it easier to understand what I am doing to troubleshoot. Once it is done I will post the link.
  • kasfamily
    • Aug 2014
    • 768
    • Russia
    Re: TV Power Problem
    may be needed Repair Kit, http://www.ebay.com/itm/Repair-Kit-L...-/230878881953
    • tech2014
      • Aug 2014
      • 807
      here is the link to the video. I will make more if you want me to.
      http://youtu.be/6lR3TKiMytc
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Ok I have seen the video the pfc seems fine check the voltage going to the relays I will try and find a schematic on this psu.
        • tech2014
          • Aug 2014
          • 807
          see video I posted above. i already replaced the main power supply which is the bigger board.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            So you have changed out the main psu, was the fault the same with old one ?
            • tech2014
              • Aug 2014
              • 807
              yes same fault. The 5v standby voltage is also wonky, it goes from 5v to 0V and no steady 5v standby .when I test all the other voltages, they all come up for a few seconds then back down to 0v. The relays click on and the RL1 and RL2 both go to about 5v then click again and back to 0V.
              I noticed that the new board(actually refurbished) is an earlier version. The old board was made in 2009 and the new one is 2007 and an earlier revision. On the original board, the VS would go up then back to 0v, and the VA was only 0.5V and wouldn't move. With the new board, the VA and VS do go up some then back to 0V.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                What are you using to get the psu to start ?
                Weird as the pfc seems fine.
                • tech2014
                  • Aug 2014
                  • 807
                  I just have it connected to the AC cord and connectors from the ac board to the main board. I am going to connect everything into the tv and make another video.
                  I would like to test the AC psi by itself without the main board. Not sure if i need a load for it or not. BTW, looked for schematic for the psu and found nothing. The service manual does have a small part but not enough to really help.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Hook it up to the rest of the set and test it, im sure that the needs a minimal load to start up fully.
                    • tech2014
                      • Aug 2014
                      • 807
                      Ok both psu are in the tv and connected to all other boards. Now I get no clicks at all, psu appears dead now. When I remove the main board from the circuit, the tv does come back on but still has fluctuating voltages then back to 0.
                      Here is link to new video.
                      https://www.youtube.com/watch?v=O7dSdMR6_Yo
                      • tech2014
                        • Aug 2014
                        • 807
                        I think I found the problem. When the YSUS board is connected to the main power supply, all the voltage lines drop down and the power turns off. Obviously there is a problem on the YSUS board.
                        • tech2014
                          • Aug 2014
                          • 807
                          Here is the video for my find.
                          https://www.youtube.com/watch?v=0jnsY4t2AB8
                          • tech2014
                            • Aug 2014
                            • 807
                            the 5v line is shorted to ground on the YSUS board. Is there a schematic for this board?
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              Hello sorry I didnt reply it was "bed time" here in england, ok so it looks like the psu did need a load to start it when the ysus is disconnected does the rest of the set start eg backlight tft panel ect ?
                              • theone111
                                by theone111
                                3. Problem: TV shuts down
                                07-22-2024, 10:36 AM
                              • Duranitron
                                Asus x512dk rev 2.1 power on problem
                                by Duranitron
                                When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
                                Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
                                11-26-2024, 10:22 PM
                              • EazyBone
                                LG OLED55C9PUA power problem
                                by EazyBone
                                Hello, trying to fix C9 55 inch. I have pulled the back and all looks completely normal with nothing burnt so far. This is first time attempting to fix a tv so any help is appreciated.
                                Problem. I hit power button, red light on TV turns off and tries to turn on, no picture shows up and then shuts off. This occurred after house power turned on and off, not from a storm.
                                I have tested the power going from power supply to main board, all 12v and 20 volt readings are proper when I hit power button.
                                The power supply to t con is different story.
                                This...
                                06-23-2023, 07:43 AM
                              • Dr.d
                                Help please..Lenovo ideapad 5 14itl05 power and charging problem
                                by Dr.d
                                I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
                                Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
                                04-05-2024, 11:48 AM
