kdl-40nx723 e double image help please
    Re: kdl-40nx723 e double image help please
    Do these voltages change when the ribbons are removed?
    • wreksta
      • Aug 2013
      • 508
      • england
      not rreally tom but whats bothering me is
      inb and out b both are 1v or lower
      according to that lad should be at 7-8v
      shed any light on this please
      • wreksta
        • Aug 2013
        • 508
        • england
        where can I get data or specs of this tcon tom
          Nobody publishes such information; anmol's info will be from his testing or elsewhere.
          I think your T-con is working OK - the IN/OUT will depend on the exact image being displayed at any one time.
          You should focus on why the image becomes distorted when only one ribbon is in place. I'd focus on the panel driver PCB and tab bonds. Maybe one of the signals is shorted on the COF IC (bad source COF IC = bad panel)
          • wreksta
            • Aug 2013
            • 508
            • england
            right if I take the left ribbon out the screen will come on then fade the pic to bright white with spots lol
            if I remolved right ribbon I get full pic on left side no errors but right stays white
              Yeah, I don't know what else to say but it has every symptom of a bad panel issue. You can try a T-con board but I don't expect any difference.
              Maybe anmol will have more ideas.
              • wreksta
                • Aug 2013
                • 508
                • england
                #27
                tom
                what is ina outa -inb outb if they control each picture side and b shows low voltage could this be an issue as anmol said the should be 6-7 v on both
                  I don't know for sure.
                  They could be low if the panel is shorted, or if one half is not outputting such a signal.
                  Maybe check each end for shorts to ground (power off, 2000 ohm range.)
                  • wreksta
                    • Aug 2013
                    • 508
                    • england
                    #29
                    explain tom please
                      Go and look up Youtube videos or online tutorials on how to use a multimeter. To be more specific, test the resistance from each point to ground, using your meter's 2000 ohm range.
                      • wreksta
                        • Aug 2013
                        • 508
                        • england
                        #31
                        ok so test vofee vone vcc33 etc yeah
                          For now, only INA/OUTA/INB/OUTB.
                          • wreksta
                            • Aug 2013
                            • 508
                            • england
                            #33
                            I don't get readings from the ina outa inb outb
                            Using meter on the 2k ohms
                            I do get readings on the other points
                              No shorts there then, so it's not an obvious fault. Any further troubleshooting is probably best done using a scope.
                              For now, my bet is 5% T-con, 95% panel fault.
                              • howardc64
                                TCL 49S405 double image
                                by howardc64
                                LCD displays a 2nd image slighty offset vertically. And multiple pairs of black lines along the bottom. Probably common as google "TCL 49S405 double image" pulls up this ifixit post ( link ) with identical ( nearly, but their fault seems to be on the other half of the panel than mine ) problem without solution.
                                This one looks to be a more difficult to diagnose because most? of TCON seems integrated ( CSOT BGA on buffer baord) into the left panel edge board ( looking from rear of TV) There are 2 buffer boards for each 1/2 of the screen. Main connects to the left buffer board...
                                06-23-2025, 03:20 PM
                              • Cornito
                                Samsung UE55RU8000 reboot and then double image after heating up
                                by Cornito
                                Hello team,
                                I'm back with another tv and another problem.
                                I try to improve my knowledge on fixing TV, and all technics used until now are not fixing correctly the problem.
                                First, reboot issue, I use tape Method to find out the right side that cases the issue.
                                Then using this it's working for quite 1hour30, then at some point of time the image became double on the bottom for half the screen.
                                Then double image reduce in height and move to the top.
                                The image is like folded on around 1cm and the bottom has been moved to the top by 1cm.
                                When I...
                                03-31-2024, 01:37 PM
                                HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                09-12-2024, 02:20 PM
                              • piershs
                                Toshiba plasma 50WP16 wierd double image fault
                                by piershs
                                My 2001 Toshiba 50WP16 50" plasma TV has, after 20 years of trouble-free service, developed a wierd fault in the last 14 days during normal viewing - with no loud bang or smoke or any other excitement.
                                Every 15-30 secs the right hand half of the image has a "glitch" for about 1 second before reverting to normal. The glitch has two forms and also depends on the aspect ratio setting (see photos):
                                • 16:9 either a) a visible seam between LHS and RHS of impage or b) LHS image duplicated on RHS (photos 16x9)
                                • 4x3 either a) no image on RHS or b) RHS image offset by 1/6th
                                08-01-2020, 01:07 PM
                                HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook 1000 Specification for Upgrade or Repair
                                This specification for the HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load, Asset Tag & Testntag boardview and 1050 G1 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                09-06-2024, 10:56 AM
