Problem with Samsung UN55ES6150F - Wont power up, 10 standby blinks
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    #41
    Re: Problem with Samsung UN55ES6150F - Wont power up, 10 standby blinks
    Hi RDMaster ,
    I repaired a similar model ( UE32ES6100 ) , also had 5 double blinks. In my case it was the power supply. Looking at your fault i would say the power supply OR the LED.
    You can try to "heat" up the power supply with a hairdryer! Just apply some heat to the power supply with the hairdryer for like 2 minutes and turn on the tv. In my case the tv turned on whenever the PS was warm.
    If not then disassemble the TV. These tv's are easy to disassemble , just 3 boards and a lcd screen with a led strip underneath.
    Remove the screws on the bezel and remove the bezel from the lcd. Release the tabs from the T-Con and remove the LCD screen.
    Below the LCD screen are the plastic covers , remove them all together at once and you will see nothing more then a led strip. If you see any burning you know the problem!
    Hope this helps!
    This vid might help a little.
    https://www.youtube.com/watch?v=X6Frth0F5x0
    • rdmaster
      • Dec 2015
      • usa
      #42
      Thanks Moreno
      Now the big question where can you find the correct Led strips I searched and have not found a set available . Also people tell me the big lcd panels are fragile and break easy unlike a 32
        Too bad the video does not show the source for the LED strips and how they are being powered.
        • FarmerBob
          • Aug 2016
          I inherited a UN55ES6150 that was replaced by a new unit by a third party warranty company that is known for doing that instead of fixing it. It's been sitting for a while since I have an incredible Samsung DLP. And recently after a new bulb and 15,000 hours of use the DLP chip is going out. And other than buy a new something to get all the widgets that the UN55 set has, I'd rather try to fix the UN55 and do the DLP later.
          I was able to get trouble codes off it and have yet to find what they mean.
          Startup: 5 blinks (said to be the start up sequence).
          Power removal gets me: 5-5-4 sets of double blinks.
          I know there is a capacitor issues with these, especially with this set, but could there be more wrong with the codes that I got? Is there a "Blink Code Index"?
          Any assistance will be greatly appreciated.
          Thank you.
          P.S.
          I will be placing this in other forums to get some coverage. Thanx.
          • Louis82
            • Feb 2012
            • 240
            Have you guys experience a problem with this tv UN55ES6100 (Power board P#: BN44-00503A) where the main AC fluse keeps blowing. I found QP801S (13NM60N) shorted. I replaced QP801S, ICM801 (FSFR1700XCL) and ICS801(D2011K) two times already and fuse, QP801S still blows.
            Any help finding the culprit would be appreciated. Thanks
            • Louis82
              • Feb 2012
              • 240
              anybody?
              • Louis82
                • Feb 2012
                • 240
                UPDATE: Found bad cap location CP819. Replaced and power board working properly again.
                  Good that you fixed the board.
                  BTW.
                  Do you mean high Voltage Cap CP818? which is the snubber cap connected in parallel with the Source and Drain pins of the PFC Power MOSFET QP801S, so if it is shorted out it will cause the fuse to blow, very common failure.
                  The CP819 is the snubber cap connected in parallel with DP808, if the cap is shorted then you will not have PFC Boosted Voltage but will not cause the fuse to blow.
                  http://www.shopjimmy.com/samsung-bn4...led-board.htm#
                  • Louis82
                    • Feb 2012
                    • 240
                    I Though about that. But, yes the defective cap was the CP819. Installed on tv and everything is working.
                    • C152Heavy
                      by C152Heavy
                      Summary for TL-DR readers:
                      • VCC pin (18) of PFC...
                      01-11-2023, 02:53 PM
                    • Destroyer-Br
                      [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                      by Destroyer-Br
                      I'm working on an Acer Nitro 5 unit with the following specs:
                      • Motherboard: LA-J871P Rev: 1B
                      • Model: Acer AN515-55-59MT
                      • S/N: NHQ7JAL00403906A973400
                      • SNID: 03902728734
                      Initial Issue
                      The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                      After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                      04-17-2025, 08:18 PM
                    • Dani_2024
                      by Dani_2024
                      10-28-2024, 05:06 PM
                      by sam_sam_sam
                      After all of...
                      07-13-2024, 08:14 PM
