hey all,
this is my thread asking for help on a specific problem. i have looked around plenty but usually a samsung np picture query results in a lot of the same results in different locations.. so here i am
i recently found this samsung at the dump. with no damage anywhere.. so i knew it was worth some effort.. heres the issue
upon initial power up the power supply clicked 3 times and didnt turn on.. so i was thrilled thinking it was an easy bad caps issue, but upon inspection i found no bad caps and realized that the set turns on after the 3 relay clicks but no picture
got into the ysus, and xsus both had good fuses and voltages were ok
Ve 63
Vs 206
Vsus -189
the buffer boards had no short circuits
if the ysus is unplugged and set is powered, the PS clicks twice and powers up, same goes for when the xsus is unplugged, 2 clicks then powers up.. if both are unplugged then the ps relay clicks once and powers up immediately.
some notes:
the chime sounds when powered up
there is no glow on the screen
the ysus does hum
the xsus does not hum
i have replaced the ysus to no avail..
how likely is it that the panel itself is at fault?
could it be the logic board?
main board?
thanks in advance
Ve 63
Vs 206
Vsus -189
some notes:
the ysus does hum
main board?
thanks in advance
