LG 42LS5700 LED-LCD - Percussive Maintenance Makes Backlight Turn On... Help!
  • Doombang
    • Sep 2014
    • 11
    • US
    The backlight on my LG LED TV is acting strange. Sometimes when I turn on the TV, the backlight doesn't come on with the rest of it. I can hear audio and the LCD is displaying a picture but no backlight. Well, give the back of the TV a firm smack or two (near the bottom) and it will turn on! It makes for a fun time with guests when it happens but its getting to the point where I'd like to fix it.
    I've popped open the back of it and turned it on, tried wiggling some connections, and no change. In this case, the backlight turned on and I wanted to see if a loose wire was the cause of the short. I inspected the solders on the power supply but didn't see anything that stood out. I've attached some pics to this post, I'm hoping for some insight into what could be causing the problem.
  • triplefour
    by triplefour
    09-13-2023, 10:43 PM
  • DanPoka
    Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
    by DanPoka
    I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
    Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
    This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
    02-15-2025, 05:05 AM
  • Comp_Pro
    No Backlight Macbook A1990 820-01041
    by Comp_Pro
    Hello all,
    Am trying to figure out this backlight issue with this A1990 Macbook Pro.
    Tests performed:
    There is no backlight even with a good screen.
    Backlight IC is receiving the correct support voltages.
    Fuse F8400 ok
    Current sense resistor R8400 ok
    Backlight IC is receiving 3.3V on enable pin.
    Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
    Backlight IC receiving 5V from PP5V_G3S
    Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
    I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
    05-06-2024, 10:23 PM
  • cheebster
    iPad Pro 12.9 5th Gen Backlight Issue
    by cheebster
    Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
    Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
    Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
    The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
    Anyone...
    05-20-2025, 09:17 AM
  • canadaboy25
    LG Flatron 24EN33TA No Backlight When Cold
    by canadaboy25
    I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
    I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
    03-07-2023, 12:23 AM
