Funai 32FL553P/10 - squealing from PSU, dies after 10 seconds, blank screen after logo, bootloops
  • kotel studios
    • Dec 2024
    • 193
    • Poland
    Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
    State I got it in:
    Squealing from the PSU
    After logo I get a blank screen
    After 10 seconds of having a blank display w/ backlight the TV dies
    Give it 7-10ish seconds again and it starts to bootloop.
    What I did so far:
    Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
    Checked all voltage rails:
    5VSB - 4.8V
    AMP+13V - 14.4V
    13V - 12.98V (in manual 12V)
    PS_ON - 4.8V (always high)
    BL-ADJ - 4.98V when TV in STBY, 4.78V when ON
    BL-SW - 0.03V when in STBY, 5V when ON
    LED1 - 2.38V
    LED2 - 2.36V
    VLED - couldn't get a reading
    The 470uF 25V caps C403,402,407 had been replaced for testing with 860uF 25V (I was out of 470uF caps)
    Now this makes me suspect two things:
    Squealing: the AMP+13V rail being out of whack, although the noise seems to come from the transformer (which can be heard even with the TV fully assembled and being like 2-3 feet away).
    Bootlooping cause: bad FW, main PCB seeing that AMP+13V is out of whack so it cuts the power (unlikely since the TV turns on after some time on it's own), or both.
    Read on a forum post that swapping the FW fixed this (squealing was caused by the PSU being unloaded).
    Any ideas?
  • lotas
    • Jan 2016
    • 4808
    • Russia
    Post your original dump (firmware) here, I'll look at it and fix it if anything.
    • kotel studios
      • Dec 2024
      • 193
      • Poland
      Dumped.
      Mainboard is MSD309.B95
      Oddly, comparing it to a dump from a working TV I found online (same model and PCB) it's waaay different. Maybe different revision or something like that.
      The one from internet is the file starting with "FUNAI_model..."
      • lotas
        • Jan 2016
        • 4808
        • Russia
        Originally posted by kotel studios
        Dumped.
        Your dump is very badly damaged, I fixed it, try it (or better yet, write it to a new SPI flash drive)
        • kotel studios
          • Dec 2024
          • 193
          • Poland
          Okay, it seems to work. Thank you!
          Now what can we do about the loud squealing from the PSU? When it's loaded it is quieter (sounds as a normal 2008 TV under normal operation).
            • 12307
            • U.S.
            Check the capacitors you replaced over, make sure they're getting good solder contact. I use the multimeter, a probe on each leg to make sure none of them are reading low ohms. Sometimes a new cap can be bad, good policy to check before installing if possible.
            • hasel17
              CH341a can erase and read but can't write and blank check
              by hasel17
              So I am trying to repair broken thunderbolt FW on X1 Yoga Gen 2. The EEPROM chip is WINBOND 25Q80DVNIG. I already do a back-up and erase. But when I try to wrote new FW, it was successfull, but when I tried to read it, it still blank. when I try to do a blank check, it gave me instant error in address 0. I already tried two CH341A, already did the 3.3v fix mod, using AsProgrammer, NeoProgrammer, Colibri, and CH341A 1.29. But the problem still occurred. What I did wrong here? Can anyone help me? Thanks in advance. Here is the log in Colibri :
              Code:
              Checking for blank...
              (Press
              10-26-2023, 06:20 AM
            • RetroComputingGrotto
              Hanns.G Hi221 Monitor - Works For A Second & Then Blank Display
              by RetroComputingGrotto
              I've got a Hanns.G Hi221 Monitor that works for a moment and then the display goes off but the power LED indicator remains on. If you power it off and back on again it does the same thing, it comes on and then the display goes blank. From a cold start it takes 10 seconds or so before the display goes blank but if you turn it off and then back on again after it already being on it goes blank a lot quicker so I'm assuming something is getting hot which is causing the display to go off.
              I've uploaded a video of it happening on YouTube:
              I've taken the monitor...
              01-11-2024, 05:37 AM
            • Chrissygizmo
              Panasonic TX-48CX350B backlights but white screen , blank screen
              by Chrissygizmo
              Hi all, I’ve got a problem I hope someone can help me fixi.
              I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
              01-11-2025, 03:18 PM
            • Spoonicks
              ASUS VH238T blank screen with backlight
              by Spoonicks
              I am having a problem with a ASUS VH238T.
              The monitor started by just going blank, but the integrated speakers, and the backlight worked. The OSD didn't pop up, neither did the messages of DVI No Signal, nor the Asus logo.
              Turning off the monitor, and turning it back on made no difference. But leaving the monitor off for a few hours returned the monitor back to normal. The problem will eventually return after a couple of hours.
              Today, it started exhibiting another symptom: the display started showing a white image, that didn't take the whole screen....
              07-04-2023, 01:29 PM
            • erdos
              My pc boot with a blank screen
              by erdos
              greetings
              My old homebuilt pc won't boot for some reason, when I pressed power on, I can hear Power supply fan running, but no bios screen, just blank and DVD-rom LED flashing.
              I've switched with a different graphics card (known good) to no avail. the pc is equipped with corsair 550W power supply and a MSI K8N Neo Platinum Mob.
              How do i check which part is the culprit for causing the issue?...
              10-22-2025, 01:33 AM
