Capacitor Indentification Help
  • mmartell
    • Oct 2013
    • 3189
    Can anyone tell me the specs on these caps ? 40uf ?? volts ? Are they called solid aluminum ?
    They are from the address board (E Buffer) from a Samsung plasma I'm working on and were sheared off cleanly when the main board bracket fell from its perch. Thanks
  • kasfamily
    • Aug 2014
    • 774
    • Russia
    Re: Capacitor Indentification Help
    What are the dimensions of the capacitors
    • mmartell
      • Oct 2013
      • 3189
      About 10x10mm
      • Ltank
        • Jun 2013
        • 776
        They are a polymer electrolytic type. Do you have a capacitance meter? Unfortunately different manufacturers have their own codes. It's not always easy.
        • mmartell
          • Oct 2013
          • 3189
          I thought the capacitance was as marked (40uf) but will check with a meter. As to the voltage would it be advisable to put a meter across the pads to read the operating voltage ?
          • Agent24
            I see dead caps
            • Oct 2007
            • 5091
            • New Zealand
            Are you sure? The vent marks on top seem to suggest otherwise.
            -David VanHorn
            • kasfamily
              • Aug 2014
              • 774
              • Russia
              These cap probably 40uf 100V. In such a board I have is cap 33uf 100v
              • mmartell
                • Oct 2013
                • 3189
                Hey thanks for that! Is this a specialty cap of sorts or can it be replaced with a standard electrolytic ? 40uf is an odd value for a cap is it not ?
                • wreksta
                  • Aug 2013
                  • 508
                  • england
                  mate give us the board number it fell off could start with lj or bn
                  • MORETTIGIAN
                    Capacitor detached from PCB – RTX 2070 Super Founders Edition
                    by MORETTIGIAN
                    Title:
                    Description:
                    During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                    I did not notice it detaching, so I am unsure of its original location on the PCB.
                    Procedure performed:
                    - Removed backplate
                    - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                    - Reapplied thermal compound
                    - Reassembled card
                    Observed behavior after reassembly:
                    - GPU powers on and operates normally under...
                    09-18-2025, 12:14 PM
                  • Prolog
                    RTX 3080 FE Identifying capacitor
                    by Prolog
                    Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                    I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                    I hope these photos make it clear which component I am referring to:
                    (yes, the soldering is a bit botched from removing the blown one, I know)
                    I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                    12-01-2024, 08:27 PM
                  • Agent24
                    Dick Smith Q-1760 linear power supply filter capacitor question
                    by Agent24
                    I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                    It has at least one problem.
                    The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                    I have already ordered a replacement potentiometer, so that's not an issue.
                    Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                    All are CapXon...
                    10-21-2025, 05:39 PM
                  • chth96
                    If I replace with inferior capacitor, Is it No harm to other IC components at all?
                    by chth96
                    I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                    Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                    It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                    So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                    I know that these capacitor will not last as long as nichicon capacitor...
                    12-22-2023, 04:34 AM
                  • chth96
                    How can I test non-polarized capacitor?
                    by chth96
                    I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                    I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                    And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                    I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                    06-02-2024, 07:31 PM
