Toshiba 55l7453d screen on but nothing else works
    • 12264
    • U.S.
    Ok, same thing for the mainboard, match up the numbers on the white stickers of both boards.
      • 12264
      • U.S.
      To explain further, the silkskreen numbers on the board you pictured are a good start to let you know the board is the same one that both tvs used. THEN they will populate the board with components to suit their needs and this is why they can be different and NOT compatible. This is why they add the white sticker, to let you know exactly what configuration was used for that particular board.
      • Chrissygizmo
        • Mar 2021
        • 125
        • United Kingdom
        I bought a universal remote & I got the tv working but when putting it back together I’ve managed to undo my good work, I think I’ve burned out a coff , is there anything I can do to fix this? I’ve marked the tcon board in yellow, when I touch the tcon in the yellow part Click image for larger version
ID:	3733710 Click image for larger version
ID:	3733711 Click image for larger version
ID:	3733712 Click image for larger version
ID:	3733713 Click image for larger version
ID:	3733714 I get a picture
        • lotas
          • Jan 2016
          • 4740
          • Russia
          What are those dark spots on the cable? Carefully inspect the contact pads on the cables with a magnifying glass to make sure they're not damaged.
          • Chrissygizmo
            • Mar 2021
            • 125
            • United Kingdom
            Yeah they are burnt, is there anything that I can do to get around this?
            • Chrissygizmo
              • Mar 2021
              • 125
              • United Kingdom
              #26
              I probably used the wrong name for them, I thought they were called cofs
              • lotas
                • Jan 2016
                • 4740
                • Russia
                #27
                It's strange, how could this happen? Something short-circuited. If it's a burnout, then it can't be repaired, only replaced with a new COF (Chip on Film), but this can't be done at home; you need specialized equipment.
                • Chrissygizmo
                  • Mar 2021
                  • 125
                  • United Kingdom
                  #28
                  No way, I think it was either the remote receiver board or the standby light board, I was putting it back together & I think one of those might have circuited it as they were lose when I was moving the tv , well it looks like I’ve repaired & broken another tv whilst putting it back together, usually it’s the screen that gets broken 🤬🤬
                  • Yehuda170
                    ThinkPad P15s Gen 1, NM-C931 REV 1.0 touch screen replaced only works in UEFI menu
                    by Yehuda170
                    original screen was BOE NV156FHM-T07 with On-Cell Touch screen I²C
                    replaced with what was in my stock, which is IVO R156NWF7 R2 which is also with On-Cell Touch screen I²C
                    now touch screen works perfectly in UEFI BIOS menu & boot menu. but not working in OS, tried windows & linux too
                    with original broken screen i can see in device manager touch screen in human interfaces
                    but with the new screen it's not showing in device manager
                    is it lenovo blocking it? is it driver missing?
                    I²C is a headache
                    07-14-2023, 01:29 AM
                    09-06-2024, 05:27 AM
                  • sigmeyer
                    Toshiba 50UL4B63DG faulty screen?
                    by sigmeyer
                    I got this 50 inch tv the screen starts off with almost nothing visible but the top part of it , and it would slowly kick in and the picture would be visible , but then over time it would go greyish with the top of it mostly intact. I did have instance where the screen would be fucked like that and i would touch the cpu and memory to see if it would react and a couple times it would screech on the speakers and restart. After that it would show a better picture somewhat but afterwards i touch the cpu and not much is achieved. Im wondering is this a screen fault or should i pursue this with a donor...
                    08-30-2025, 08:13 AM
                  • reformatt
                    by reformatt
                    07-31-2025, 08:37 PM
                    09-06-2024, 05:59 AM
