QN55Q80 backlight good no picture
  • jason123
    • Oct 2015
    • 1136
    got this TV for a friend to look at. Non-responsive to PWR button. Main board gets warm, the the optical audio light is on. Faul pin is zero volts. I am getting 33v on Vdrive. 12.76V on B13 & A13. Vamp is 17.3V.
    Disconnecting panel cable to main - no change. Disconnecting small ribbon from main to led driver board, backlight comes on.
    Do do you guys think? I am thinking main board issue?
  • lotas
    • Jan 2016
    • 4850
    • Russia
    All manipulations with disconnecting cables from the panel, you must first install a feedback jumper and disconnect the U-shaped cable connecting the two halves of the panel and then check the behavior of the TV.
    • jason123
      • Oct 2015
      • 1136
      Thank you.. Jumper installed (what doe it do?) and the U cable disconnected on one side. Behavior is unchanged. Do I need to try anything in particular?
      • lotas
        • Jan 2016
        • 4850
        • Russia
        The feedback jumper simulates that the panel is connected to the motherboard, and runs all the voltages coming from the T-CON, try disconnecting only the Lvds cable, from the motherboard side.
        • jason123
          • Oct 2015
          • 1136
          LVDS from Main Board to Panel disconnected from the main board side - no change (non-responsive, no activity)
          • lotas
            • Jan 2016
            • 4850
            • Russia
            Well then there is a high probability that the problem is in the motherboard...
            • Diah
              • Feb 2013
              • 6558
              LOL. of course will be no Picture as you have only one LVDS. so panel will be out from circuit..
              you said you have optic are on.. do you have sound ? did yours LED BL turning on ?
              • jason123
                • Oct 2015
                • 1136
                Main boards are fairly expensive for this TV, so as a last shot I reflowed the processor professionally, and long behold.. TV is alive again! I noticed the processor didn't have any thermal pads on the bottom part of the board, though the metal backing has a raised areas. So I added a thermal pad - Fingers crossed - let's see how long this will last. The fact that a reflow fixes the issue for a bit, means that most main board sold online (by TV repair shops) are reflown and as bad / good as mine
                Thanks for the help.
                • lotas
                  • Jan 2016
                  • 4850
                  • Russia
                  There is a professional reball, and there is a reflow, if it is done professionally, it should work for a long time.
                  The main thing here is that the panel is alive, the rest can be found (motherboard, power supply, ...).
                  • jason123
                    • Oct 2015
                    • 1136
                    Unfortunately, I had to do the reflow - No stencil for the footprint
                    • jason123
                      • Oct 2015
                      • 1136
                      Is there a reballing service that you or anyone would recommend? Used Main PWA is roughly $72 on eBay, but my fear is that it's just gone through reflow. Something with warranty would be great. Thank you
                        • 12328
                        • U.S.
                        I believe he gives a year warranty: https://nickselectronics.com/product...repair-service
                        • jason123
                          • Oct 2015
                          • 1136
                          Thank you.. I reached out and awaiting response. They don't have the specific board number on their site. Thanks
                          • Diah
                            • Feb 2013
                            • 6558
                            buy stencill and bales from Uncule ali then do it yours self
                              • 12328
                              • U.S.
                              Well it would be cheaper but it's not an easy task: "Quote" "BGA reballing is a very challenging and delicate process requiring specialized tools, high precision, and significant technical skill, making it a difficult task for beginners and a complex operation even for experienced technicians."
                              • Mgiffune
                                by Mgiffune
                                06-09-2024, 10:28 AM
                              • TR103
                                by TR103
                                - it keeps rebooting
                                01-22-2025, 04:12 PM
                              • K212
                                Samsung QE65Q700TATXXC is not starting
                                by K212
                                my Samsung QE65Q700TATXXC has stopped working recently. It worked fine during the morning, and when trying to start it later the same day it just refused to start.
                                The standby LED is working, but nothing happens when pushing the power button, other then the LED blinking once. No picture, no sound, no chime, no relay click. I tried a cold start, and other recommended fixes from Samsung. Nothing worked. Then i even tried to reflash the firmware, but nothing happened, not even flashing of the standby led etc.
                                I contacted Samsung support who said it is most...
                                07-31-2025, 12:45 PM
                              • Ierwin
                                by Ierwin
                                05-13-2025, 03:31 PM
                              • Patrick501
                                Philips 55PUS6704 no picture, backlight ok
                                by Patrick501
                                I'd like to repair a Philips 55PUS6704.
                                It turns on and you can see the backlight, hear the sound but no picture.
                                When I disconnect one of the T-con cables, half of the screen turns white.
                                right cable disconnected= right side white
                                left cable disconnected= left side white
                                When I tape like 6 or 7 pins of one cable it looks like the picture attached. I already tried another T-con board without success.
                                There are no shorts on the the mainbaord and the two lcd panel boards...at leat I couldn't find any.
                                Also you can notice one single...
                                11-12-2025, 08:46 AM
