I have in my a big shorcut in home, 2 LCD died. 220V here. Now reading info about this thread i opened
https://www.badcaps.net/forum/showthread.php?t=40056
I looks like the P/N on the board is BN44-00340A? If it is, it is SAMSUNG power supply board. See SCH of 340B.
http://www.shopjimmy.com/samsung-bn4...upply-unit.htm
Can you please verify?
340B is compatible with 340A so the pin out of the connectors are the same.
The board has pull-up resistor for the POWER ON/OFF (PS_ON) and the BL_ON so you can disconnect the cable between the power supply connector CN802 and the main board, then plug the TV into the outlet the backlights should come on right away, if it does then the power supply board is OK."
Yes i tested this one, and i get power of backlight,
http://postimg.org/image/xnjzplewt/
white poits is backlight works, now what is the next step? main board died? eeprom flash broken with shortcut? can be reprogrammed? or change board?
thx for your time of read this!
