LG 43SM5KB Backlight working but no image
  • Pxxx3104
    • Jun 2025
    • 8
    • Philippines
    Good day! Does anyone here familiar with the TCon from LG: 6870c-0532b. The problem is that the TV displays no image but backlight and audio from TV is good. I have checked the 125V/2A fuse and it reads 160~180 ohms. Could it be that the only problem is the fuse? Any suggestions and recommendation is highly appreciated.
    Note that it is only my first time to try and troubleshoot TVs.
    Thank you and have a nice day!
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4465
    • Italy - Milan
    Get deeper on the fuse pressing probes and twisting, retest the fuse..
    • lotas
      • Jan 2016
      • 4754
      • Russia
      So check the voltage relative to ground at the input of this fuse and at its output.
      • Pxxx3104
        • Jun 2025
        • 8
        • Philippines
        I am currently away from the TV now. I will get back to this thread when I get my hands back on the TV. Thank you for the answers guys!
        • Pxxx3104
          • Jun 2025
          • 8
          • Philippines
          Hi! It took longer than I expected to get back to the TV. I checked the input relative to ground and it is ~13.20V but on the output side it only reads ~11.19. I already tried to replace the LVDS ribbon but still no luck.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4465
            • Italy - Milan
            replace the fuse..
            • Pxxx3104
              • Jun 2025
              • 8
              • Philippines
              So I went in and replace the fuse. But sadly it's still not working. Any checkpoints I can check to verify if the issue is within the Tcon or from somewhere else?
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4465
                • Italy - Milan
                Retest the fuse, it's so strange a drop of 2v on it.. you probably have a short on the tcon..
                • Pxxx3104
                  • Jun 2025
                  • 8
                  • Philippines
                  i will just replace the tcon. i'll get back if I already receive and replaced the tcon. thank you for your replies
                  • ktmmotocross
                    Asus G513QE keyboard and backlight not working
                    by ktmmotocross
                    Have this Asus G513QE with keyboard, keyboard backlight and Led backlight not working. other works ok.
                    i measure all voltages ok on keyboard, KB backlight and Led backlight. looks like a kbc error.
                    but as laptop works i think it cannot be bad. maybe its FW. have anybody some hint for this?
                    08-08-2025, 06:29 AM
                  • stoian_93
                    Finlux LED backlight not working
                    by stoian_93
                    Hello guys!
                    My Finlux TV backlight stopped working. I disassembled the TV, saw I don't have the tools to replace the backlight and assembled it again without replacing anything. So then the backlight started working again.
                    A day after it is also not working.
                    I decided now to remove the back cover and get the output voltage to the backlight. I placed the TV facedown and connected to the mains, so - nothing. I disconected, removed the cover and connected again to the mains and then the backlight lighted again. So strange.
                    Output voltage when light is 66V.
                    Board: VESTEL...
                    08-19-2023, 12:32 AM
                  • Attila Jamilov
                    Which fuse is responsible for backlight on Lenovo Thinkpad T14 Gen 3
                    by Attila Jamilov
                    I upgraded display from HD to UHD recently, and I think I did everything right, battery was disabled in BIOS, and removed, yet the screen has no backlight. Both the old and new display behave the same way. I checked the motherboard and I see the fv1 fuse, and a fv2 spot for a fuse, but it's missing. Does anyone have any information on whether fv2 is responsible for backlight, or why it's missing? There's a schematic posted somewhere on this forum, but I can't view it as I don't have the hardware right now, since the laptop screen is broken and I run Linux.
                    Also from further search...
                    04-20-2025, 10:02 PM
                  • pseudorc
                    Philips 43PUS8550 no image, backlight working
                    by pseudorc
                    Checking voltages at TCON
                    Vin 12 V ok BUT ALL OTHER VOLTAGES 0
                    VGL1 0
                    VDD
                    vcc19
                    VGH 0
                    when connection to Left half screen cable disconnected - then other half becomes white and voltages shows down below
                    VGH 27.96
                    VCC19 1.89
                    HVDD 8.31
                    VGL1 5V
                    VGL2 3.8
                    TCON board has been replaced with similar (bought from Ebay)
                    Is this LCD panel issue ? the parts showing parts no is lg 6870s-2704d
                    Many thanks...
                    09-02-2024, 03:08 PM
                  • zaurus81
                    Yashi All in one model AY62409 (Quantum S 24'') no image (backlight works)
                    by zaurus81
                    This chinese all in one computer gives an image when connected to an external vga monitor but only the backlight with integrated monitor (no image). Initially I thought it was an edid problem on the eeprom of the screen but then I saw that the monitor works correctly with another identical motherboard (model th410-d4, read by bios). Unfortunately the motherboard is chinese and has no brand or codes on the pcb. The format seems ITX. Nothing can be found online. The official yashi site provides drivers but not the bios. The electrical diagram is obviously unobtainable
                    The board is equipped...
                    01-16-2025, 03:54 AM
