JVC AV 27850 Horizontal lines flicker at bottom
  • printone2
    • Jun 2007
    • 102
    I just replace two caps in the vertical deflection area of the main board. I had done some reading on the problem and others had indicated that they had solved this kind of problem by replacing caps in this area.
    The picture looks good with the exception of the bottom 4 inches, which has lines that flicker all the way across the screen, but only on the bottom. After replacing a 470uf 35v and a 2200uf 25v cap, the picture may have improved a little, but the majority of the disturbance still exists at the bottom.
    Would the vertical deflection be the right area to correct for this kind of a problem? Are caps the probable culprits in this scenario?
  • tvtech
    • Oct 2006
    • 48
    Re: JVC AV 27850 Horizontal lines flicker at bottom
    Sounds like your vertical is stretched out on the bottom,you may need to replace your output ic if checking/replacing the rest of the caps in the circuit doesnt fix it
    • Wizard
      • Mar 2008
      • 2296
      YES, swap that vertical IC and resolder rest of the horizontal section and the outputs of that horizontal transformer (lot of solder fractures).
      Cheers, Wizard
      • ggil44
        Sony XBR-65X750D Horizontal lines bottom of screen
        by ggil44
        Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
        05-30-2023, 07:51 PM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • kdaniel
        Hitachi 58HK6100U - Horizontal Lines (Bottom third of the screen)
        by kdaniel
        As stated by the person I collected the TV from, it just stopped working overnight. However, I still gave it a go to try and repair it.
        There is a thread on the same TV but with slightly different issues where they had to tape connection points on the ribbon cable, so I want to see if this is repairable by any chance.
        After bringing it home and plugging it in, the TV turned on with its backlight working but had no picture. After removing the back cover, the first thing I tried is to unplug one of the ribbon cables and the situation is as follows.
        Left...
        11-16-2022, 09:23 AM
      • DrvLikHell
        Sharp (Hisense) LC-55p6050u - Flashing/dimming row of pixels
        by DrvLikHell
        Hello again! I have come back for some wisdom and hopefully for some guidance with this problem I'm having. The TV is a 4k 55" Sharp LC-55p6050u and the problem is every other line of the bottom 32 lines flickers out, comes mostly back, then flickers out again, and repeats this continually. The lines on the bottom right of the screen go out completely while the lines on the bottom left are affected so slightly that it's almost impossible to see it. There is a gradual gradient from appearing almost perfectly fine on the bottom left, to an obvious problem on the bottom right.
        The...
        02-05-2025, 01:44 AM
      • x_orange90_x
        Samsung UN46C8000XFXZA Horizontal lines
        by x_orange90_x
        I just acquired this 3D LED yesterday and it has horizontal lines on a little more than half of the screen. When I first turn it on it has thin black lines going across that makes the image look serrated, and then shortly after patterns of thicker red lines fade in. If I turn it off and right back on it will reset to just the black lines and the red will again fade onto the screen.
        I initially thought tab bonds, but flexing the bezel makes no difference, and the fact the image sort of resets after cycling power is different. I haven't opened it up yet to actually test applying...
        07-15-2023, 05:06 AM
