NonWorking Samsung LN40C630?
  • KenOlson
    • Jun 2011
    • 81
    Hi
    Recently inherited a nonworking Samsung LN40C630 with no signs of external damage to either the screen or front and back body.
    While this is the first LCD I have worked on, have been taught to check for burnt and broken components and PC boards, and count flashes and beeps when turn unit on/off.
    To date I have only plugged the set in and turned it on and off with these results.
    When plug in the AC cord the set makes a short musical sound(MS) and the power light(PL) flashes 6x then off.
    When turn the set on get shorter (MS) and (PL) stays on but there is no screen light.
    When turn the set off get shorter (MS) and (PL) flashes 5x then off.
    Searched the forum and found Samsung LN40C630 "No Signs of Life"
    https://www.badcaps.net/forum/showth...light=LN40C630
    and Samsung LN40C630 won't turn on
    Neither posts mention musical sounds and flashing power light so I hope my problem is less serious!
    Appreciate any tips/suggestions concerning dismantling the set to be able to check the fuses and other components.
    Googled using "Samsung LN40C630" problems and found "Samsung LN40C630 Backlight Problem" http://www.avsforum.com/forum/166-lc...t-problem.html
    From same search:
    "Bulged Capacitor Problem, Tv Does Not Turn On Anymore"
    http://www.helpowl.com/q/Samsung/LNT...anymore/107201
    "Replacing Bad Capacitors"
    http://www.helpowl.com/q/Samsung/LN4...acitors/211072
    Seems like some Samsung LCDs may have Bad Caps!
    Hoped to find a database listing most frequent problems for the LN40C630 but have not found it yet.
    Am interested in any problems others have found for these sets.
    Ken
  • selldoor
    Slow Learner
    • 7870
    Re: NonWorking Samsung LN40C630?
    https://www.badcaps.net/forum/showthread.php?t=39740
    • KenOlson
      • Jun 2011
      • 81
      Hi selldoor,
      Thanks for the photo tip!
      After opening the back checked the 2 fuses and the front and back sides of the Power Board (PB) and Main Board (MB).
      The 2 fuses were OK and I did not notice any burned/broken components or traces on either board. Upper left of MB noticed Switch SW701.
      Then removed the MB connector and plugged the AC cord in and the LCD back light came on.
      Pushed SW701, reconnected MB and when connected AC cord got 5 power LED flashes and short music, touched power and LED came on and stayed on (no flashes) but no screen came up and the Input Mode and Menu did not work.After ~ 1 minute touched power and got 5 flashes and short music and set turned off. Also got same results with a DVD player connected to AV2.
      Wonder if these flashes are same as PC BIOS "No Boot" beeps?
      Appreciate any comments!
      Ken
      • mmartell
        • Oct 2013
        • 3189
        On Samsung tv's the flashes mean nothing. Do you get audio when you cycle through the inputs with the dvd player connected ?
          At this point it is the main board problem (the backlights come on when cable between main and power supply is disconnected which means the power supply is OK).
          I never have luck fixing Samsung main board. You can contact shopjimmy to see if they have any suggestion.
          You can also report the DC voltage readings on each pin of the connector CN802, just to see what you have.
          • KenOlson
            • Jun 2011
            • 81
            Hi mmartell,
            "Do you get audio when you cycle through the inputs with the dvd player connected?"
            Never tried because nothing came up.
            Did not receive the dedicated Samsung LN40C630 have only the controls on the set to use.
            Any suggestions how to check the audio?
            Ken
            • KenOlson
              • Jun 2011
              • 81
              Hi budm,
              "...You can contact shopjimmy to see if they have any suggestion."
              Am new do not know what you mean but if give me detailed instructions will try.
              Ken
                ShopJimmy is a parts retailer, mainly selling TV parts. http://www.shopjimmy.com
                  09-07-2024, 05:50 AM
                  09-06-2024, 11:40 PM
                  09-06-2024, 08:40 PM
                  Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                  This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  09-06-2024, 06:20 PM
