Bad Panel 2 ?
  • mmartell
    • Oct 2013
    • 3189
    Bad Panel 2 ?
    This is an LG 50PK540. Is this a bottom buffer ribbon that needs reseating or is the panel on its way out ?
    Re: Bad Panel 2 ?
    It's rare for plasma panels to fail in such a way, check ribbons & for Va on that board. Careful do not reseat with power applied or shortly afterwards.
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • NWArkGuy
      Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
      by NWArkGuy
      Well, I will be the first to admit that I screwed up...
      In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
      I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
      I have 2 that I have found and have in my possession. ...
      10-12-2023, 10:13 PM
    • howardc64
      Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
      by howardc64
      • Prior owner tried a replacement main board. No difference.
      • Samsung 2x red blinking standby LED = panel fault
      • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
      • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
      • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
      07-19-2025, 10:54 PM
    • howardc64
      LG 49UJ6500 LCD panel lighter band that goes away
      by howardc64
      49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
      Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
      02-19-2023, 12:13 AM
    • triplefour
      SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
      by triplefour
      TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
      tcon is built into mainboard.
      Only one cable goes to panel boards.
      there is a cable from one panel board to the other that links them.
      cost cutting measure that results in us having harder time to diagnose.
      removing the link to the second panel board allows TV to stay on with stable backlight but no image.
      used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
      07-28-2022, 07:59 PM
