Problem - unlit screen. With all original modules in place I have on my Y board --VS- 199v VA- 54v VY- 177v VSC- 149 (these are within 1 volt of correct voltages), Z board -- VZB- 40v and drops off (This one is supposed to be 110v). All other PS voltages are ok also. I have tried a replacement Z board. With that in place my VY and VSC voltages drop to nearly nothing on the Y board and VZB on the Z board is still not correct. What are you thoughts? Do I have a bad replacement Z board or possibly is my Y board bad or both Y and Z. Also the logic board (control bd) led flashes 2 short 2 long, repeat. I have a feeling that is a trouble code as from what i have found when set is working properly the led should be constant. Thanks for your help! I really appeciate it. Marv
Lg 60pv250
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
Assuming...7 Photos -
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... -
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... - Loading...
