RCA 42" RLDEDV3988-a flickering video
  • bufferb
    • Jan 2016
    • 10
    • canada
    Re: RCA 42" RLDEDV3988-a flickering video
    Originally posted by caleb
    glad you found it! Can you post the location and part number so people reading this thread later can find it easily.
    is there a charge to find out,were this resistor is located.?????
      First of all this TV model uses LED backlights so it does not have Inverter board or circuits for the CCFL, so I am not sure what inverter he is talking about.
      May be we can start by uploading good clear pictures of all the boards and start from there.
      • Caleb
        Smokin IC's
        • Feb 2013
        • 645
        @Bufferb, sadly a lot of folks come here and receive help for their repair and never return to let us know if it was fixed and where the trouble was. As budm said we can narrow down the suspects with some pictures if you would be so kind to post them. The pictures on the original post are far too blurry to be of use, There only appears to be one combined power/ av board. The Op discovered the bad resistor when testing the led power source so the trouble is likely to be very near there.
        Liberating magic smoke one part at a time
        • johnboy1313
          • Nov 2012
          • 1959
          Originally posted by bufferb
          SO you wont tell us what RESISTOR,SO I & 100 more people are spending
          2 hrs trying to find this resistor.with no luck.IS this april fool's day or what.
          NOT very HAPPY.
          WHY hasent this repair been told to members.YOU found a resistor what RESISTOR & WERE.
          This thread is almost two years old. I doubt you'll get a response.
          • Nick's Tvs
            • Jan 2014
            • 621
            Its probably a surface mount resistor on the back side of the power supply. However if he found it while checking for currents, it is very possible that if you check them in circuit it will read a different part so you will have to take them out of circuit and or wait for him to reply about the location.
            • fixerguy81
              • Nov 2016
              Originally posted by tech2014
              i fixed the tv. I was doing voltage measurement on the secondary side inverter section and found an open surface mount resistor. Replaced the part and problem solved. Thanks for the input guys.
              can you reply back to where you found the fix, a lot of people want to know where you fund the resistor that was giving the problem. Thanks.
              • fixerguy81
                • Nov 2016
                • lsdawayen
                  Check the Led backlights. have the same problem here. just fix it by replacing some led.
                  • jjanssen7
                    • Nov 2012
                    • 252
                    For the record, same here. Flashing LEDS fixed not by repairing a resister but by replacing LED strip.
                      HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                      This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                      09-12-2024, 02:00 PM
                    • ugamazing
                      Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                      by ugamazing
                      I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                      We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                      12-17-2024, 07:05 PM
                    • reessi
                      ACER BM320 Monitor - Horizonal Flickering Lines After a While
                      by reessi
                      The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
                      They are black on the right and gradually fade to nothing on the far left.
                      They start either after 5 mins or up to 2 hours after so annoying for testing.
                      They flicker continuously very fast! With a slight pause milli-second every second.
                      Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
                      I tested each half by removing the first the left flex from...
                      06-03-2025, 09:58 AM
                      GeForce RTX2080 Super Aero video gaming card issues help need
                      This is from my son’s gaming computer that at first had minor overheating issues when playing a very intense game with it causing the computer to crash or reboot
                      Then bough a new motherboard and a new computer case that a cooling system in it already installed also brought the cooling system for this video card but now the issue with it is that it randomly rebooted screen goes blank randomly and suddenly video freezing or started with video being there then blank screen and then the video comes back or it just stays blank for a while and then maybe it will come back but it...
                      05-07-2023, 08:12 AM
                    • Rick_1234
                      by Rick_1234
                      Good evening, gentlemen.
                      Things I tried
                      06-22-2024, 04:44 PM
