TV SAMSUNG QE55Q80RAT
  • porfyriadhs
    • Oct 2023
    • 80
    • Greece
    Hello to everyone i have TV SAMSUNG QE55Q80RAT tv with reboot problem i tried to tape the cable from panel to motherboard . The tv started ok for a moment but after a while i get a line at the left of the screen . and need help if anyone know a way to fix it
  • William1967
    • Nov 2017
    • 217
    • Netherlands
    Replace the COF or the complete display. Because the COF is rarely or never replaced and the display is expensive, it will be a scrap TV...
    • porfyriadhs
      • Oct 2023
      • 80
      • Greece
      What you mean replace the cof. Dont get it
      • William1967
        • Nov 2017
        • 217
        • Netherlands
        COF = Chip on Flex or Chip on Film cable. It's one of the cables between the display itself and the modules you find at the bottom of the tv.
        • porfyriadhs
          • Oct 2023
          • 80
          • Greece
          But in order to Change old cof you need a special tool. It is not something easy to do by hand
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4516
            • Italy - Milan
            if you have a lot of space store them as many as you can, my guess is them are all fixable, when the fix technique will arrive, you'll be probably happier, a special recommendation, cover them absolutely perfect as them suffers from moisture and certain natural gases (present in each home)
              09-07-2024, 05:50 AM
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
            • cubytus
              Samsung UN50TU8000FXZC shows thin horizontal green line when warm
              by cubytus
              Hi to all,
              I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
              I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
              Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
              01-10-2024, 01:26 AM
              09-06-2024, 11:40 PM
