LG TV no power
  • tech2014
    • Aug 2014
    • 807
    LG TV no power
    I have an LG 60PC1D that has no power. The standby LED is on the tv when the power supplies are in the tv, but the standby voltage goes to 5v when the relays click, then down to 0v. Had found a 10 ohm 5 Watt resistor open, replaced and still no joy. Getting frustrated with this TV, very hard to troubleshoot without schematics. Any ideas?
  • tech2014
    • Aug 2014
    • 807
    Re: LG TV no power
    After connecting everything in the tv, I am only getting about 110V max for VS and only about 0.3V for VA. Does this mean there is a problem with the VA circuit.
      Re: LG TV no power
      Try unplugging Y-sus/Z-sus and see if Vs/Va rise. Do you have 390V PFC voltage? Pictures of the boards too!
      • tech2014
        • Aug 2014
        • 807
        Re: LG TV no power
        I do have PFC voltage and I tried unplugging the Y SUS and Z SUS and no change. Any voltages I get are momentary and go back down shortly after power up
        • Notsure
          • Jul 2014
          Re: LG TV no power
          remove buffer bds one at a time. should run w half a pix if that's the problem.
          • tech2014
            • Aug 2014
            • 807
            Re: LG TV no power
            I will try the buffer boards idea, haven't done that yet. thanks
            • tech2014
              • Aug 2014
              • 807
              Re: LG TV no power
              tried the buffer boards and no change. My standby 5v keeps jumping around and not a steady 5v. Maybe its the standby 5v circuit. there is an LDO regulator KIA278R05PI.
              • GLISIT
                by GLISIT
                01-16-2025, 02:29 PM
                03-31-2024, 02:12 PM
              • SkishyIshy
                Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
                by SkishyIshy
                Hey All,
                I have a Sony 65x900f that I purchased cheap because of a no-power issue.
                I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
                I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
                03-17-2021, 11:44 AM
              • AleMonti
                LG 55EG910V - no power and no standby light
                by AleMonti
                I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                After checking the basics I did the following:
                • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                11-04-2024, 05:02 PM
              • redbaron1007
                Yamaha HTR-3065 No power/No Standby
                by redbaron1007
                I got a Yamaha HTR-3065 on the bench currently that's got a no power/ no standby issue.When I plug it in it draws 0.01A from the wall, the relay for the ac transformer never clicks, there are no standby lights on the front, and pressing the power button does nothing. The fuse was not blown but upon measuring the voltages on the power low voltage power supply board (labeled operation 3 pg 89 in the schematic) they do not match what the schematic says they should be.
                S9 13.7V
                Pwr Ry 0V
                AC Det 9.1V
                Mgnd 0V GND
                The two pins on the transformer for the operation...
                09-12-2024, 03:04 PM
