I have a bad diode on a aps-254 power board I cant identify, its the one with the red arrow pointing to at D6105. anybody know what I can replace this with?
APS-254 power supply on a 40" sony
Tags: None
Re: APS-254 power supply on a 40" sony
I guess they are big rectifier diodes. If you find what they connect to, it should be evident what function they perform.
There seems to be a part number on them. I can make out a 4 on one and a 6 on the other. Desolder one and tell us what all the numbers are."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHorn -
It looks like it is connected to the Aux winding of the transformer next to it to produce VCC voltage to the SMPS IC once the SMPS starts running.
Is the standby power supply section dead? Diode tested as shorted or open circuit?
http://www.shopjimmy.com/sony-1-474-...-g2-board.htm#Never stop learning
Power Supply Sony AZ1-L G2LE_ APS-254 schem.
RegardsComment
Thanks guys, yes it tested shorted while the one beside it tested good. No standby power at all. Will desolder when i get home. There was another diode that tested ok but value seemed low, 217, while most test much higher. Can they be bad but short out?Comment
Ok its out but tests good out of circuit? what am I missing here. I tested the solder points and got 59ohms like when the diode was inComment
You are right tw2005, found a pic of it online with the numbers you provided. am looking over the schematic to get a better idea what to check next. thanksComment
It looks like D6105 supplies VCC to the PFC controller
Have you checked that the supply is getting mains voltage OK, at least to the primary filter capacitor?
Is there anything else you have checked or tried?Last edited by Agent24; 08-23-2014, 03:51 PM."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHornComment
I put the diode back on the board and put power to it. im getting 65volts across the fuse. I thought it would read 120v ac. I have tested all diodes and transistors, seem ok.Comment
A fuse is just a wire, close to zero ohms - if not blown, there should be zero volts across it.
If there is voltage across it, the fuse may be blown. Unplug the TV and check the resistance of the fuse, it should be approximately zero ohms\short circuit.Last edited by Agent24; 08-23-2014, 06:13 PM."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
What DC voltage do you get MEASURE AT THE TWO LEGS OF THE MAIN FILTER CAP 120uF 450VDC?
What resistance do you get between the Cathode pad of D6105 and the negative leg of the main filter cap?Last edited by budm; 08-23-2014, 08:57 PM.Never stop learning
zero ohms on the fuse. I am using the chassis for a ground for the meter, I usually use an open screw hole on the frame. I have fixed the vizio ldr problems on my own TV's, and 6 others. So im still learning, try to research as much as I can before asking. but this one is a new ball game. and the 50" Samsung I just learned what was bad on it. will go thru the resisters tomorrow and anything else I can test.Comment
When you work in the primary side of the circuit you do not use chassis as the ground ref point. When measure the DC voltage in the primary side, the negative leg of the main filter cap is the circuit ground ref point, when you want to check the Incoming AC voltage feeding the primary circuit, you measure between HOT and Neutral.
So what DC voltage do you have on the main filter cap?
What resistance do you get between the Cathode pad of D6105 and the negative leg of the main filter cap?Never stop learning
OK now the only volts that are getting to the main board is a 3.3volt standby. but I hear now click or see any signs of life when I try to power up the tvComment
I hear no clicking or signs I meant. Thanks budm, I will check those in the morning and get backComment
So did you put the Diode D6105 back in place OR you left it out?
If you leave out the D6105, then the standby power supply will be able to start up, but if you do have low resistance between the Cathode pad ans the primary GND, then if the diode is put back in it will stop the standby circuit due to heavy load on the cathode side of the D6105.
If you leave out D6105, then the PFC voltage booster circuit will not function so the TV will not start up properly, we need to know if you do have low resistance on the Cathode pad of the D6105 or not.Last edited by budm; 08-23-2014, 09:31 PM.Never stop learning
I put it back in. It tested good out of circuit. If im getting standby power to the board, could it actually be the logic board that has the problem?Comment
So that low resistance reading on the pad of the Diode is gone?
You need to find out next if you do have PS_ON signal from the main board or not to turn on the PFC Voltage booster which the DC Voltage on the main cap should go up from 170VDC (if you are in the USA) to about 400VDC when PS_ON is present.
BTW, we need the model number of this TV and the pictures of the whole back side of the TV so we can see what we are dealing with here.Last edited by budm; 08-23-2014, 09:35 PM.Never stop learning
by sam_sam_samI was working on this CNC machine today found no keyboard functioning no control relay powering on
The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
Found shorted diodes on main controller relays there are 3 of them that... -
by JimBanvilleThe sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
Opened it up and discovered the power supply is making a faint clicking or ticking sound.
I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...-
by TnmgI have a Sony XBR-65X850E that when plugged in buzzes for a few seconds about 5-7 times but the screen never comes on. It looks like one of the four diodes on the main power supply board are bad. I'd like to replace all four at the same time. The diodes that are bad are the D750, D751, D752 and D753. The S750 looks discolored and fails the diode test on the board. It hasn't been removed from the board yet for testing.
Are all four of these the same diode? I saw a video that called the discolored one a Schottky 5150 diode. How can I make sure to get the right diodes for these?... -
by modtoolDear forum members,
I'm working on this power supply for ps4 slim, that behaves in a similar manner as other cases but I can't find a way to solve the problem.
When it came to me, externally the ps4 had standby voltage, clicking the disc eject button made the triple beep (without disc inside) and cliking on the power button made the blue power light turn on and then all turned off within 1 second.
When I opened it up, I found these components shorted:
Q6 24N60M2
IC41 1612A (not really shorted but had a hole on it and all pins measured open circuit but the 9th... -
by sam_sam_samI saw this switching power supply on eBay and wanted to see if could be modified to run 14.5 volts before the blocking diode was add and this switching power supply seems to have no issues doing this
I did recap the switching power supply except the the main filtering capacitors and I managed to break the selector switch for the voltage setting but just jumped it
One note I used 25 volt capacitors on the output side of this power supply because they used 16 volt capacitors and because I am running the voltage up a little bit higher 12 volts to 14.5 volts there would... - Loading...
