On the SS board the LED for the +15volt is lit, have checked most of the voltages and after switch on they all appear but then they go off. I changed the SS board but fault is still the same. If the +15v detector is lit, this means the voltage is missing, I assume ??.will post picture later.
Panasonic TH-42PE30 fault no picture fault code 2 blinks
Re: Panasonic TH-42PE30 fault no picture fault code 2 blinks
I think 2 blinks is Vsus fault, have you tried isolating SC and SS boards to see if error code changes?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
From memory, 12 is an audio fault. Try unplugging speakers, check speaker wire for shorts, check speakers are about 8ohm each.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Disconnected PA1,PA3,PA5,PA6 and PA7, when putting them back in with PA7 disconnected, the screen lit up but only for about a minute, when retried this it did the same, so it looks like the 15v is being loaded.Comment
Have done more checks. with P12 removed, no clicking or relays and no blinking LED. replace P12 and remove P5, this gives 5 blinks, replaced PL5 and remove P23, this gives 2 blinks, replace PL23 and remove P7 this gives 12 blinks. Any thoughts.Comment
In schematic states that 12 blink code is: "PA board Base Voltage (15, 12, 9, 5, 2.5V)".
Maybe some of the sub-voltages on the PA board is missing, try to measure voltages on PA2 connector.Comment
Have checked the voltages on PA10 to PF10.
Pin one and two Unr 21v, Voltage rises to 22.1v, then trips.
Pin five unr 14v, Voltage rises to 15.5v, then trips.
Pin seven stb 5v, Voltage rises to 5.3v and remains constant.
Pin nine AC on/off, Voltage rises to 2.3v, then trips
Any thoughtsComment
Thanks for the reply, have done further checks and found if I remove plug D3 the power stays on, so I thought it would be the D board, but got the board today and still have the same problem. Have checked all the main voltages and all are within spec. Also some times the set will switch on and stay on upto 30minutes, other times it will stay on for a few minutes. The only video I could display was the PC channel. So whats the chance the problem is in the DG board ??????.Comment
by RictechHello everyone. 😀
As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
There are no devices that have exploded or otherwise show signs...-
by FZGHello!
I recently got an old VHS player from Panasonic and just for fun I want to try to repair this device. It is an AG-1000B portable VHS player from 1990 and it has a problem with picture quality in playback mode.
Picture in playback mode is very noisy and often loses sync but the still images are nearly perfect.
I want to know, is this something that could be solved by recapping or is the video head likely gone?
Also, what mechanism is this?
Any feedback is appreciated!...05-06-2024, 07:16 AM -
ALL LCD LED TV SERVICE MENU CODES
Service Menu Code with Board Name
China Universal Board / Jumper Board Service Menu Code
Changhong Ruba Service Menu Code
Ecostar LED TV Service Menu Code
Orient LED TV Service Menu Code
Haier LED TV Service Menu Code
TCL LED TV Service Menu Code
Samsung LED TV Service Menu Code
LG LED TV Service Menu Code
Videocon LED TV Service Menu Code
Supra LED TV Service Menu Code
Toshiba LED TV Service Menu Code
Symphony LED TV Service Menu Code
Veste/ LED TV Service Menu Code...-
Channel: Schematics and Boardviews
10-31-2024, 03:58 AM -
by jm1234Hi,
anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
I checked that board for any obvious faults... -
by clooI recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
After doing a factory reset this problem was gone and the picture was back to...01-06-2025, 06:02 AM - Loading...
