how do u repair main board with no hdmi
  • mattstolte
    • Dec 2013
    • 612
    • usa
    I have come across this in the past and normally would just replace board but got a friend that needs it fixed and was gonna look into just trying to fix or change something on main to get HDMI working again. Anybody? Please explain
  • mmartell
    • Oct 2013
    • 3189
    Re: how do u repair main board with no hdmi
    If you follow the traces from the hdmi port you will see they go to an hdmi controller ic. That will probably have failed and needs replacing. How many hdmi's are onthis tv and have they all failed or jjust one ?
      • 30978
      check the hdmi connector soldering first - they break loose real easy.
      • mmartell
        • Oct 2013
        • 3189
        Yes, good point if it's only one port that has malfunctioned.
        • Dani_2024
          by Dani_2024
          10-28-2024, 05:06 PM
        • jb_Bak
          by jb_Bak
          CN6401
          Pin 01 NC
          Pin 02 NC
          Pin 03 "BL_ON": 0V
          Pin 04 "N/C"
          Pin 05 "STBY 3.3V": 3.5V
          Pin 06 "GND": N/C
          Pin 07 "AC_OFF"...
          09-27-2021, 04:52 PM
        • JDC
          by JDC
          ONN 100012588
          Long answer:
          07-15-2022, 07:39 AM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • cheeky2
          by cheeky2
          05-25-2024, 03:27 AM
