TV bea ba-4920s black screen
  • Zippo978
    • 47
    • Italia
    I have a TV with a black screen but working backlight.
    Thinking it was the T-Con board, I replaced it, but the problem persists. I tried unplugging the flat cables connecting it to the panel, first one and then the other, but the screen remains black. I also tried masking the pins, but nothing, I don't know what to do.
    Thanks everyone.
  • Zippo978
    • 47
    • Italia
    Does anyone have any ideas?
      • 12200
      • U.S.
      Pictures would help, need good focused pictures of each board and one of the whole back as to see how everything is connected.
      • Zippo978
        • 47
        • Italia
        Sorry for the delay, here are the photos of the TV
ID:	3698655 Click image for larger version
ID:	3698654 Click image for larger version  Name:	IMG20250806112328.jpg Views:	0 Size:	1.88 MB ID:	3698660 Click image for larger version
        T-Con Main Full view Connecting to the panel
        • lotas
          • Jan 2016
          • 4610
          • Russia
          It is necessary to install a jumper on T-CON between points FB331 - FB332 and then disconnect one LVDS cable at a time.
          • x_orange90_x
            • May 2015
            • 727
            I had a similar situation with a TCL once before. The screen was blank no matter what I did. I gave up for a while and left it sit in the corner and then one day brought it back out for one last try. This time I actually got a half screen when disconnecting one of the ribbons. I found the pins for clock signals and blocked them and it's been working relatively fine in my son's bedroom since. It has noticeable lines from the missing signals, but from a few feet away it looks normal.
            I suggest you keep trying with those ribbons. Also check near the HDMI and inputs for a reset button. If it has one you may need to hold that in/press it a few times. Short of this there could be an issue with the main board not out putting any video. In this case there *may* be a way to get the tcon to display a test pattern with the main board unplugged. I've never accomplished this, but some other members may be able to help with that.
            • Zippo978
              • 47
              • Italia
              With jumper and the right flat cable removed I have half a screen, while with the left flat cable removed I have a black screen.
              • Zippo978
                • 47
                • Italia
                Thanks guys, between the jumper and the pin masking, the TV works now. It has some subtle horizontal lines, but they're only visible from very close up.
                Thanks again.
                • HTR-Informatique
                  by HTR-Informatique
                  02-09-2025, 06:51 AM
                • howardc64
                  by howardc64
                  Problem
                  08-04-2024, 10:36 PM
                • VcemPzd
                  Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                  by VcemPzd
                  Hello everyone !
                  My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                  04-28-2025, 10:14 AM
                • DaniK
                  Acer Aspire E5-574-52RH - black screen
                  by DaniK
                  I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
                  Laptop came in for a SSD upgrade, took everything apart to install the SSD.
                  Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
                  Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
                  The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
                  Symptoms are:
                  - random black screen after displaying Acer logo...
                  02-21-2024, 06:27 AM
                • turmix
                  AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                  by turmix
                  Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                  The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                  At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                  During another reassembly, I made a mistake, and...
                  01-29-2024, 03:48 AM
